ibjeepin95's 99' XJ Build - Page 135 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > ibjeepin95's 99' XJ Build
Unread 04-07-2014, 11:56 PM   #2011
kyle_craig
I have gone back and forth on the axle debate so many times with my rig. I've come to the conclusion that no matter what axles I run, I will be maxed out on tire size. With built stock axles I'd run 35s or 36s, with 44s maybe 38s, and with tons I'd run 40s or 42s. No matter what I'll be breaking stuff. So screw it, it doesn't really matter. I have a buddy who breaks countless parts with a front 44 and 38s, and another with a front 44 on 40s that I've never seen break. Both are v6 trucks with doublers. My point is that smart driving goes a long way. I too have a hard time justifying spending a substantial amount more just to run a 2" taller tire.
My biggest worry about my 30 has always been the ball joints. I've wrecked a hand full of shafts and U joints and that is always an easy fix. If I wrecked a pinion or a locker I'd probably just limp off the trail. Ball joints can be a real mess to fix when they come apart on the trail though. Luckily I haven't busted mine yet...knock on wood.
kyle_craig is offline   Reply With Quote Quick reply to this message
Unread 04-08-2014, 06:58 AM   #2012
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
^^^This I agree with.
Everyone I wheel with, with the exception of 1, builds their axles to put bigger and bigger tires under their rig. No one puts heavy duty axles in to play it safe with the tires - and they always break something. So - seems to me it's all the same in the end.
~Mike~
Build Thread WK
Other Build Thread XJ
September 2013/January 2015 COTM
JeepN4KC is offline   Reply With Quote Quick reply to this message
Unread 04-08-2014, 11:22 AM   #2013
ibjeepin95
I here you on all of this. My biggest worry with the 30 anymore is ring gear deflection...
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 04-08-2014, 11:28 AM   #2014
crockett07
1992 XJ Cherokee
As long as you build the 30 like you said, I think you'll be fine on 35's. And if you're not spitting shafts out of the 8.25, run it until it becomes a problem!
crockett07 is offline   Reply With Quote Quick reply to this message
Unread 04-08-2014, 11:38 AM   #2015
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Thats what Im saying!
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline   Reply With Quote Quick reply to this message
Unread 04-08-2014, 12:14 PM   #2016
Luke95
I guess I'm weird then. I only want 35s.
Resident XJ lowlife. 35 general reds on 3inches of lift.
Luke95 is offline   Reply With Quote Quick reply to this message
Unread 04-08-2014, 12:54 PM   #2017
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
This is not new information. .!..!.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 04-08-2014, 01:19 PM   #2018
ibjeepin95
You're not weird. That's all I want...
Unread 04-08-2014, 01:19 PM   #2019
ibjeepin95
Kinda what I was thinking.....
Unread 04-08-2014, 03:30 PM   #2020
Luke95
We'll yeah I guess. But seriously I have a dana 44 and all I want is some nice new 35s preferably on some bead locks. But I doubt that will happen.
Unread 04-08-2014, 03:31 PM   #2021
Luke95
Wat.
Unread 04-09-2014, 05:27 AM   #2022
ibjeepin95
Wat.
All I want is 35's, no bigger.
Unread 04-09-2014, 06:15 AM   #2023
Luke95
The first part of that sentence.
Unread 04-13-2014, 04:15 PM   #2024
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
4d's
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline   Reply With Quote Quick reply to this message
Unread 04-13-2014, 05:52 PM   #2025
Project1
Originally Posted by SFRautomotive View Post
4d's
They look reallllly nice on an XJ ...
Project1 is offline   Reply With Quote Quick reply to this message
