ibjeepin95's 99' XJ Build - Page 119 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > ibjeepin95's 99' XJ Build
Time To Save On Yukon Lockers!Rough Country Lift Kits and Parts!Ruffstuff 10 year sale
Unread 10-19-2013, 09:40 AM   #1771
kyle_craig
Ordered a set of 4.56's. Giggity.
Schwweeeeeeeettt!
kyle_craig is offline   Reply With Quote Quick reply to this message
Unread 10-19-2013, 06:47 PM   #1772
lyle147
They eliminate the shackle. They ride much smoother and are much more predictable.
What do you mean by more predictable?
lyle147 is offline   Reply With Quote Quick reply to this message
Unread 10-19-2013, 06:55 PM   #1773
MattBillyTayloe
He knows what they will do when he puts them in certain situations.
MattBillyTayloe is offline   Reply With Quote Quick reply to this message
Unread 10-20-2013, 08:31 AM   #1774
ibjeepin95
Yes.
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 10-20-2013, 08:33 AM   #1775
MattBillyTayloe
Originally Posted by ibjeepin95
Yes.
In learning make sure you post moar pictures, especially of the boxes, I'm doing flush tail lights on the yj when I get it
Unread 10-20-2013, 08:58 AM   #1776
crockett07
1992 XJ Cherokee
Hey lbjeepin! What welder do you use
crockett07 is offline   Reply With Quote Quick reply to this message
Unread 10-20-2013, 09:59 AM   #1777
ibjeepin95
Right now just a Lincoln 110v. Will be looking for a Miller 220v soon. Saving my pennies!
Unread 10-20-2013, 10:02 AM   #1778
ibjeepin95
Started building some boxes...
Unread 10-20-2013, 10:15 AM   #1779
crockett07
1992 XJ Cherokee
Yea I've been looking at the Hobart 190 from good ol tractor supply. It claims to be able to weld 5/16 and I don't see me welding anything bigger. Anyways I thought I read once you had a Hobart. Sorry for the rant, boxes looking good!
Unread 10-20-2013, 10:17 AM   #1780
ibjeepin95
Thanks man. Hobart's are fine. However, consider a Lincoln or Miller from an actual welding store. Better quality.
Unread 10-20-2013, 03:16 PM   #1781
1990JEEPXJ
1990 XJ Cherokee
Hobart is made by miller so it's fine. I got my Hobart from northern tool. Nary a problem. If you can swing it and have 208/230v available, get a welder that can be used with either 120 or 208/230. My Hobart can use either with a simple change of a plug.
My POS
1990JEEPXJ is offline   Reply With Quote Quick reply to this message
Unread 10-20-2013, 07:06 PM   #1782
ibjeepin95
Didn't know that about Hobart.
Unread 10-20-2013, 09:14 PM   #1783
Luke95
Hobarts are titties I don't use much experience but I loved the 210 machine I used. It burned the 1/4 I was welding insanely well!
I <3 rockrash
Resident XJ lowlife. 35 general reds on 3inches of lift.
Luke95 is offline   Reply With Quote Quick reply to this message
Unread 10-21-2013, 12:02 AM   #1784
rebelbowtie
Made by but not the same quality, its a good home garage welder but there is a reason Miller and Lincoln dominate the commercial/Industrial welding world.
rebelbowtie is offline   Reply With Quote Quick reply to this message
Unread 10-21-2013, 08:50 AM   #1785
1990JEEPXJ
1990 XJ Cherokee
I say it's the same quality but Hobart doesn't have quite the same features a miller does such as the auto set feature or infinite adjustability of the output for comparable models. And since we are talking about garage use a Hobart should be looked at since they're a few hundred cheaper than millers for similar models.
My POS
