ibjeepin95's 99' XJ Build - Page 102 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > ibjeepin95's 99' XJ Build
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 06-25-2013, 08:02 AM   #1516
Luke95
Congrats on the Cherokee of the month ****!
Resident XJ lowlife. 35 general reds on 3inches of lift.
Luke95 is offline   Reply With Quote Quick reply to this message
Unread 06-25-2013, 11:09 AM   #1517
ibjeepin95
Thanks dood!
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 06-25-2013, 11:15 AM   #1518
Motorcharge
Bandeded
Motorcharge's Avatar
1991 MJ Comanche
Haha, you wouldn't want it. It's all tweaked and that one leaf is too short. Unless you like leafs that try to flatten out!
Nah, I fort enough of that now lol
| Project Motörcharge 2.0 - MJ | June 2015 COTM |
Motorcharge is online now   Reply With Quote Quick reply to this message
Unread 06-25-2013, 11:15 AM   #1519
Luke95
Originally Posted by ibjeepin95
Thanks dood!
No problem
Sent from my xj
Unread 06-25-2013, 11:18 AM   #1520
ibjeepin95
Exactly!
Unread 06-25-2013, 12:03 PM   #1521
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Do you have an pics of your exhaust setup? The rocks took mine and wont give it back.
Im looking to do something up and out of the way, and I was thinking you might have a setup like that.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline   Reply With Quote Quick reply to this message
Unread 06-25-2013, 06:17 PM   #1522
aircruiser
I just cut my tail pipe right after the axle on my white one so it comes out right behind the right rear tire point at the ground but it sits up high..same height as the gas tank.
My black one is dumped just before the axle, out of the way but can get a little annoying and its stock. Only thing I like loud are V8s and diesels tho haha
aircruiser is offline   Reply With Quote Quick reply to this message
Unread 06-25-2013, 06:27 PM   #1523
Motorcharge
Bandeded
1991 MJ Comanche
Exactly!
have* stupid phone lol
That's where I cut mine at. My cheapo tailpipe didn't come with a hanger point for the back end. Cutting it was easier than welding one on.
Unread 06-25-2013, 06:32 PM   #1524
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
I intend to cut mine how your black one is, the tailpipe wasnt the problem as much as my gigantic cat catching a rock. I think Ill probably just go with a thinner profile cat, Dynomax muffler, and cut down stock tailpipe.
And im like you. If its not diesel or V8 then it needs to shut the **** up.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 06-25-2013, 06:34 PM   #1525
Luke95
Turbo i6s I can dig but other than v8s them and diesels no.
Sent from my xj
Unread 06-25-2013, 06:47 PM   #1526
aircruiser
Sent from my xj
Im not going to say much but my co-worker is huge into drift cars, done plenty of engine swaps and such and hes got an xj hes getting a 50 trim turbo for, already has all the oil lines figured out and exhaust routing and said if I wanted to buy fittings lines, same turbo, BOV and waste gate for mine and go halvsies on exhaust tubing he would help me turbo mine. I am highly considering it
Unread 06-25-2013, 06:49 PM   #1527
aircruiser
Gotcha, I fully weld all my exhausts for that reason haha. Had a turn down on my old 2 door and caught the cat on a rock while bumping a hill climb and it ripped off so hard it pushed the turn down into my gas tank and put a nice hole in it. Dont do a sharp tip turn down is my advice lol
Unread 06-25-2013, 07:42 PM   #1528
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Haha good advice.
And yea Ill be welding up my own since no matter how I tuck it up it is likely to happen again.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 06-25-2013, 07:47 PM   #1529
Luke95
Hy35 is being fit into mine it's a ***** to fit in haha
Fmu because **** tuning
30lb injectors because she's gonna be thirsty as **** under boost
New tranny because **** the 230k one
Sent from my xj
Unread 06-25-2013, 08:43 PM   #1530
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
Haha good advice.
Stacks!
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline   Reply With Quote Quick reply to this message
