ibjeepin95's 99' XJ Build - Page 94 - JeepForum.com
post #1396 of 2369 Old 05-31-2013, 01:18 PM
crockett07
1992 XJ Cherokee
Originally Posted by Weeder1
I though they were just cool?
Totally rad
crockett07 is offline
post #1397 of 2369 Old 05-31-2013, 05:23 PM
JJeeper09
I would like to see a jeep with mostly stock components and trac bar up from like Colton's case, meaning not a whole lot of custom work up there. Knuckles, trac bar, custom steering, and DS in a XJ. You can't just get 18 inch CO's and not expect to spend a **** load more money and custom fab work. They don't just "go" in. And certainly not an 18 CO to be run using the travel that is given with it.
Colton can get progressive Savvy coils and custom tuned shocks... Probably a 12-14 rage of travel on his setup he is running now and be happy as hell. It's much easy said then done buying and setting up CO's cheaply.
Colton you know this already, LOL
JJeeper09 is offline
post #1398 of 2369 Old 05-31-2013, 05:40 PM
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
It's really not that difficult. Hoops through the hood.
Now I'm not saying he needs them though.
And he would have a hard time packaging a 14" travel shock with that low of lift using stock mounting points. And even a progressive coil will unseat wayyyy before the shock maxes out.
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline
post #1399 of 2369 Old 05-31-2013, 05:43 PM
JJeeper09
Well that proves my point... 18 inch would be too much. I'm not sure who even said it, but I'm just saying. I know about stock mounts and such, that's why I said it would be more money and custom work....
post #1400 of 2369 Old 06-01-2013, 07:03 AM Thread Starter
ibjeepin95
Exactly. And packaging a damn 12 in the front of an XJ is hard enough unless I run some in ungodly tall lift height. Of course, unless I run my uppers higher.
ibjeepin95 is offline
post #1401 of 2369 Old 06-01-2013, 04:37 PM
Luke95
How?
Im at fit in 10 inch travel no issue with 1 inch of drop on the shock no problems
I think that If you were to go to a shock tower you could fit a 12 inch shock easy
Yes I know I am a pavement pounding *****, the track bar needs to come over a half in and that I have ABS lines with no point.
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #1402 of 2369 Old 06-01-2013, 06:11 PM
alexrule123
alexrule123's Avatar
I run a 12" travel shock up front but I guess my lift height is ungodly and it will roll going over a speed bump.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #1403 of 2369 Old 06-01-2013, 07:55 PM Thread Starter
ibjeepin95
Originally Posted by Luke95 View Post
How?
I can't run my current mounts and bumps with a 12. I COULD fit a 12, but I would have ZERO up travel.
Yes .!..!.
post #1404 of 2369 Old 06-01-2013, 08:04 PM Thread Starter
ibjeepin95
3 link worked flawlessly today. It may have been a Jeep dealership show, but they put on a good obstacle course. I beat the absolute piss out of the Jeep today and it never skipped a beat. Had a bunch of different people ride with me and every single person complemented on how smooth it rode and flexed through the rocks. I really noticed that it doesn't roll or "kick" back when it tries to climb anymore. Instead, it just bites and goes. Only thing I don't like about it is that the lower mounts are too low, but I can't expect much more out of a "kit". I was surprised at how well it went through the Jersey barriers. I saw many bigger (and much taller) rigs struggle on them. I had to use some technique, but I got it through just fine. The cross member, frame rails, and rear bumper took a hell of a beating today. Anyways, I'm not sure why, but the vid quality sucks. But you get the idea....
https://www.youtube.com/watch?v=_eYBcLaFe4Y
https://www.youtube.com/watch?v=CXFBsXKrF6M
post #1405 of 2369 Old 06-01-2013, 08:15 PM
JJeeper09
Looks cool, glide over those walls. If you went to far over that would suck.
When is the next open wheeling in Crozet?
post #1406 of 2369 Old 06-01-2013, 08:24 PM Thread Starter
ibjeepin95
Too far over, as in, off the side? That damn near happen once when I got hot on the skinny pedal
Have you kept up with the issues going down at Crozet? It's been a mess, but there should be some wheeling there this month. I WILL go when it opens back up.
post #1407 of 2369 Old 06-01-2013, 08:37 PM
JJeeper09
No what's going down? The app on my phone stopped working so I haven't looked at it. What's going on?
post #1408 of 2369 Old 06-01-2013, 08:39 PM Thread Starter
ibjeepin95
Tree huggers, well, mainly some crazy b!tch from Charlottesville is/was trying to doom them. There has been a bunch of news articles and stuff, and it came down to zoning basically. From what I've heard from a few buddies who have been in contact with Chris, things are definitely looking up, and wheeling should resume this month.
post #1409 of 2369 Old 06-01-2013, 09:28 PM
JJeeper09
Sounds absurd. I'll have to check into it
post #1410 of 2369 Old 06-01-2013, 10:38 PM
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
And there you go, for anyone who claims a 3 link isn't worth it.
2013 COTY
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
