ibjeepin95's 99' XJ Build - Page 84 - JeepForum.com
post #1246 of 2369 Old 04-28-2013, 09:43 PM
Luke95
I might!
Good! I want to see this thing wheel in person
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #1247 of 2369 Old 04-28-2013, 10:22 PM
Showtime3492
Traded my XJ and some cash for this:
Just kidding, I wish. RC was a lot of fun. I'd like to run a class 1 or 2 rig.
I was there with Down n dirty Offroad.
--1998 XJ "Mater"- RIP
2000 XJ--- 4.6 stroker. Saved from the grave- everything swapped or modded. I hate this thing :)
Showtime3492 is offline
post #1248 of 2369 Old 04-29-2013, 07:55 AM
VegasGT
1988 MJ Comanche
I know its been covered but does the 3.55s really pull 35s ok? Sometime this summer I will likely pick up new tires and trim and Im really hung up on if I should play it safe with 33s or jump into my manhood and go 35s. I just dont want to get in over my head and do 35s and watch my to do list of necessary mods go way up. I just know last time I went with 33s on 4.5 I was wishin I woulda went on up to 35s. Ill have to live with my next tire purchase a while.
And im asking this with the "bigger is better" ideaology set aside lol. Im trying to be semi-realistic haha
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #1249 of 2369 Old 04-29-2013, 08:03 AM
koolaid5
Stuck In The Garage!
koolaid5's Avatar
1992 XJ Cherokee
DEFINITELY go with 35's, but then start saving for gears. I know with just 33's and 3.55's I was great on the highway, but really noticed the lack of low end torque on the trails. Really sucked when trying to climb even in 4 Lo. My .02
koolaid5 is offline
post #1250 of 2369 Old 04-29-2013, 08:16 AM
VegasGT
1988 MJ Comanche
Thats what Im afraid of, lol. I never really noticed much of a problem with 33s but with 35s itd probably be a different story, and if Im going to regear id likely want to put that money into an 8.8 instead to be safe. So thats an axle swap and gears. Then my steering needs upgrading, and Id likely wanna run stiffeners after than. Plus I at least need to put together a front bumper for recovery.
Ideally I need to do all the supporting mods first but by the time money allows for all that then Ill be broke again and need tires. Ive got one tire thats new and the others are 50 percent or less as it is. Where I wheel 31s can do the job ok but some of the tougher still will be hard and most things will still take more skinny pedal. 33s will likely do the job bit if Im going to bump up in size Im thinking I may as well go all out and do 35s. But then there I am digging into a money pit again.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
VegasGT is offline
post #1251 of 2369 Old 04-29-2013, 08:20 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Get the 35s, and save up for gears like he said.
Usually you can find places that will re-gear both axles for around ~1100. I'd jump to 4.56s
Do you have a 8.25 or D35? If you have an 8.25 I wouldn't even worry about an 8.8 unless you plan on going bigger than 35s in the next year or so.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #1252 of 2369 Old 04-29-2013, 08:27 AM
VegasGT
1988 MJ Comanche
I do have a car also I can DD but the Jeep is a very good driver as is and I enjoy driving it, so I dont wanna get so crazy and kill its driveability either. While the car is clean and a reliable DD, its just a 96 Corolla (wifes first car) so I def prefer driving the Jeep haha.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
VegasGT is offline
post #1253 of 2369 Old 04-29-2013, 08:35 AM
VegasGT
1988 MJ Comanche
Im rocking a 29 spliner so all good there.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
VegasGT is offline
post #1254 of 2369 Old 04-29-2013, 08:51 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Previous:
DNFJ is offline
post #1255 of 2369 Old 04-29-2013, 08:54 AM
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
+1 - if you have the 29 spline I wouldn't worry about an 8.8. All of the other mods you listed don't have to be done immediately either. Pick up your tires and save for the gears or whatever is highest on your want list. I would put recover points at the top of that personally. Just pick up each of the items one at a time and you'll be fine. If you don't want to or can't do that then just stick with your 33's for now and keep your eyes peeled on CL for some used 33's or 35's to replace your current ones. I just sold a set of 35's with GREAT tread and 3 spares, one of which was brand new for $400. You can always find great deals on CL.
koolaid5 is offline
post #1256 of 2369 Old 04-29-2013, 09:14 AM
VegasGT
1988 MJ Comanche
Thanks for the advice. Im not too worried about getting it all done at once to try and meet some standard of a built Jeep really, just trying to get the main things. From past experience with 33s on an XJ I know the first thing I will be addressing is steering box bracing (via JCR spacer and tie-in brackets I whip up for the front bumper). I had some issues in the past with stress cracking around the box. Durango box upgrade will be on the list but Ill see how long the stocker hangs on.
Otherwise Id just like to run it and fix **** as needed. Im still a lil bit away from 35s due to still needing to pick up an SYE and other such things but its getting close. Im just concerned about driveability, my wife is my designated driver often and I dont wanna hear bishing.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
VegasGT is offline
post #1257 of 2369 Old 04-29-2013, 11:07 AM Thread Starter
ibjeepin95
VegasGT, like koolaid said, 35's aren't bad on 3:55's, but start saving for gears. I don't DD mine, so that helps, but I do plan to get some 4.88's. Like he said, it does lack on the trail just a little. In 4 lo, it's a little "fast" when crawling. As far as shying away from an 8.25, why even ask!?! Look at mine. Welded, on 35's, and I beat the ***** out of it. I've never broke it (yet), and the only one I have seen break is the same setup as mine, but 36" TSL's and it was getting hammered on with most of the weight of the Jeep on one tire.
ibjeepin95 is offline
post #1258 of 2369 Old 04-29-2013, 11:40 AM
VegasGT
1988 MJ Comanche
Good to know. Ive always had good luck with the 8.25 but never ran one on 35s so was wanting firsthand experience. Glad to hear strength wont be an issue. At this point Im just trying to get my order of purchases down pat based on what Im lacking.
Its easy to get caught up in the big tire game but Ive found that my tire size hasnt hurt my fun factor of wheeling near as much as my ******* open diff. Its still a while before I pull the trigger on big rubber, and Ive considered just going with 32" Duratracs, but then I see your Jeep and HARDCOREXJ's rig and wonder why the hell I dont have 35s yet lol.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
VegasGT is offline
post #1259 of 2369 Old 04-29-2013, 11:41 AM
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Yeah, I just installed my SYE, so I have a spare transfer case if anyone wants to buy it. That way you can install the SYE in it leaving your Jeep drivable in the process and then just swap them out one afternoon.
I also need to upgrade to a durango box and still need to reinforce the inside of the box. Outside is braced with my front bumper mount. I do have alittle bit of stress cracking there that I am going to try and weld up too.
koolaid5 is offline
post #1260 of 2369 Old 04-29-2013, 11:43 AM
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Agreed. . . Bump up to 35's. Don't waste your money on 32" duratracs. 35's and a pair of lunchbox lockers and you'll be set. Then some gears and other little things here and there.
koolaid5 is offline
Jeep Build: Minty White Country XJ Build GTEIS300 Jeep Builds 34 01-20-2013 11:42 AM
2000 TJ Build - LCG First Time Build japete01 Jeep Builds 82 06-07-2012 10:50 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 12:15 PM
WeatherWarrior's "you better not call it a build" build thread. WeatherWarrior Jeep Builds 10 12-12-2011 06:31 PM
JeepDVL45's 'Bruiser' Build -- A Daily Driver's slow build JeepDVL45 Jeep Builds 41 08-11-2011 10:44 AM
