ibjeepin95's 99' XJ Build - Page 70 - JeepForum.com
post #1036 of 2369 Old 03-25-2013, 03:27 PM
Luke95
I got a ***** pile of 2x3 1/4" steel, so I'll just add onto it with that. My bumper is flat with the grille, but I will make the wings stick out a little to fend off trees and rocks.
That what I was thinking. So on that note I am tired of this lcog fad. 3 inchs lift and 33s is small not LCOG. Vent off.
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is online now
post #1037 of 2369 Old 03-25-2013, 03:29 PM Thread Starter
ibjeepin95
Originally Posted by koolaid5 View Post
Did he have a collar and tags, so that you could at least let the owner know? I would have been sobbing like a little ***** and it would be very painful to contact the owners, but I couldn't live with myself if I didn't. My 3 dogs are part of the family. It's like I have 5 kids instead of just the two.
Nope. I have 2 dogs myself. It sucks, but like I said, it happens all the time around the same spot. It's unfortunate, but there are so many houses through there that it's impossible to find who the dog belongs to.
ibjeepin95 is offline
post #1038 of 2369 Old 03-25-2013, 03:31 PM Thread Starter
ibjeepin95
I don't look at it like a "fad". I do it because it works. Like I've said, it takes just as much work if not more to make a low XJ work then to make a tall lifted XJ work.
post #1039 of 2369 Old 03-25-2013, 04:50 PM
Luke95
On my new one I have a simple plan. And I'm going to keep it that way. Not to be low but be stable and well built.
Sent from under my broken Heep
post #1040 of 2369 Old 03-25-2013, 05:52 PM
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
So much truth.
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline
post #1041 of 2369 Old 03-25-2013, 06:21 PM
aircruiser
aircruiser's Avatar
So basically, youre new one will have a Low Center Of Gravity..
aircruiser is offline
post #1042 of 2369 Old 03-25-2013, 06:28 PM
Luke95
yes. But thats not the direct point of the build, more like something I can wheel, DD, and not have to worry to much.
small built jeeps can be cooler than unbuilt big jeeps
post #1043 of 2369 Old 03-25-2013, 06:29 PM
MattBillyTayloe
He acts like its a bandwagon lol. I prefer the look of low and beefy than tall, and I hear the problems people have after going 4.5" and up, lol, no thanks. I'll stay "small" as he puts it
MattBillyTayloe is offline
post #1044 of 2369 Old 03-25-2013, 06:44 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
What problems do you speak of? I'm at 6" and no problems. And have a good balance of up travel and droop and belly clearance
1990JEEPXJ is offline
post #1045 of 2369 Old 03-25-2013, 06:54 PM Thread Starter
ibjeepin95
I would imagine he means drive line / suspension geometry. Even if you stay low,you should still correct these issues. I didn't need an SYE because of my suspension height, but because of my transfer case being pushed up because of my cross member and causing drive line issues. As far as suspension, yes, short arms have a better geometry at lower heights.
post #1046 of 2369 Old 03-25-2013, 07:00 PM
MattBillyTayloe
I can't name something off the top of my head, I'm jut going off of what other people have said. I think they were referring to stuff they had to replace upgrade be auss of going higher, as well as what ibjeepin was dating about driveline and steering geometry
post #1047 of 2369 Old 03-26-2013, 05:05 PM
ahar9
Steering, drivelines, brake lines, control arm angles, higher center of gravity so less stable, that kinda ****. I think low is the way to go although it's not because you don't have to deal with some of those problems. You actually end up paying more building a lower rig.
hold my beer
ahar9 is offline
post #1048 of 2369 Old 03-26-2013, 06:41 PM Thread Starter
ibjeepin95
X2. I've also done much more fab work to make low work than I would've had to do to make a tall rig work.
post #1049 of 2369 Old 03-26-2013, 06:44 PM
MattBillyTayloe
Speaking of fab, did you make your own sliders, of so, any idea where that page is ? trying to get some together soon, less scrape and bend more slide.
post #1050 of 2369 Old 03-26-2013, 07:07 PM Thread Starter
ibjeepin95
Page 14 broski
http://www.jeepforum.com/forum/f177/...2/index14.html
Jeep Build: Minty White Country XJ Build GTEIS300 Jeep Builds 34 01-20-2013 11:42 AM
2000 TJ Build - LCG First Time Build japete01 Jeep Builds 82 06-07-2012 10:50 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 12:15 PM
WeatherWarrior's "you better not call it a build" build thread. WeatherWarrior Jeep Builds 10 12-12-2011 06:31 PM
JeepDVL45's 'Bruiser' Build -- A Daily Driver's slow build JeepDVL45 Jeep Builds 41 08-11-2011 10:44 AM
