ibjeepin95's 99' XJ Build - Page 21 - JeepForum.com
post #301 of 2370 Old 09-17-2012, 08:08 PM
BomberJeep
2011 WK
Great work and great looking XJ man. Keep it up
Never get between a man and his Jeep - Stacey David.
BomberJeep is offline
post #302 of 2370 Old 09-17-2012, 08:20 PM Thread Starter
ibjeepin95
Thanks dude! Good to hear from another VA Jeep guy!
ibjeepin95 is offline
post #303 of 2370 Old 09-19-2012, 03:39 AM
DezertXj88
1990 XJ Cherokee
Ok..so say you didn't do the shocks through the floor..what issue is there? When on 3" and 35's?
I mean obviously rubbing up front, bump stop & trimming is needed, same for the rear. Cut & fold recommended so your not rubbing..but what else is there?
DezertXj88 is offline
post #304 of 2370 Old 09-19-2012, 08:59 AM
jeepnatv4life
have u read the hole thread lmao????? He has shock hoops in the rear......
XJ 35's locked Gas Tank in the Trunk Shox Hoops in the rear.
'13 RZR 570
jeepnatv4life is offline
post #305 of 2370 Old 09-19-2012, 10:23 AM
crockett07
1992 XJ Cherokee
Whole*
crockett07 is offline
post #306 of 2370 Old 09-19-2012, 11:32 AM
Weeder1
Originally Posted by crockett07
Whole*
Lol just like a chick......
-98 xj sport-
http://www.jeepforum.com/forum/f177/weeder1s-xj-build-1391067
Weeder1 is offline
post #307 of 2370 Old 09-19-2012, 11:51 AM
DezertXj88
1990 XJ Cherokee
Did you not read my question?
IF you didn't do shock through the floor, what would the potential issues/draw backs be
I know he has shocks through the floor, I'm asking the draw backs of 35's without them through the floor
post #308 of 2370 Old 09-19-2012, 12:54 PM
alexrule123
alexrule123's Avatar
It depends on the amount of lift you have. You have to trade up travel with down travel and have the shock body fit in the small amount of space under the jeep.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #309 of 2370 Old 09-19-2012, 02:38 PM
DezertXj88
1990 XJ Cherokee
Ya I figured it was more of a shock travel thing..basically with then mounted through the floor he can run a 14" or 16" or whatever to get the down travel he needed..
post #310 of 2370 Old 09-19-2012, 03:42 PM Thread Starter
ibjeepin95
Yup, Alex has it right. I wanted to mount my lower shock mounts on top of the axle so they were out of the way. My lower mount is currently on the spring plate. The only shock I could could have mounted there would have been a stock style shock with no travel, so that wasn't happening. After I did the hoops, I continued (and still am) running the 10 inch shocks I had. Eventually, after I get to doing some shackle relocation brackets and redoing the springs, I will go to a 12 inch shock because it will give me the most down travel and just enough up travel.
post #311 of 2370 Old 09-19-2012, 04:57 PM
DezertXj88
1990 XJ Cherokee
Aww so it was because you moved the lower mount. Thats what I was after. Shock shocks in stock location it shouldn't have an issue!
post #312 of 2370 Old 09-19-2012, 06:35 PM Thread Starter
ibjeepin95
Yup. Main reason for the hoops was for longer shocks and just to simply outboard them. Outboarding them allows the shock to actually work like it's supposed to. Of course, fitting a shock was another important reason.
post #313 of 2370 Old 09-20-2012, 04:31 PM
Weeder1
Well in think you need clayton lowers...
-98 xj sport-
Weeder1 is offline
post #314 of 2370 Old 09-20-2012, 05:26 PM Thread Starter
ibjeepin95
I do. 150 is shipped?
post #315 of 2370 Old 09-20-2012, 05:41 PM
Weeder1
Yupp
-98 xj sport-
Weeder1 is offline
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
