ibjeepin95's 99' XJ Build - Page 20 - JeepForum.com
post #286 of 2369 Old 09-04-2012, 01:02 PM Thread Starter
ibjeepin95
Originally Posted by Brookhart63
Stock D 30's don't like 35s. Especially at full lock.
They hate full lock and skinny pedal. But they hold together on 35s better than most think they do.
ibjeepin95 is offline
post #287 of 2369 Old 09-04-2012, 01:16 PM
Brookhart63
Had to change a shaft on some rocks this weekend. Like you said don't think your jeep is invincible
Bought not Built
Jeep Outdoor Club of Cental Iowa
Square Headlight Jeep Club
Brookhart63 is offline
post #288 of 2369 Old 09-04-2012, 07:07 PM Thread Starter
ibjeepin95
Exactly. But sometimes I do
post #289 of 2369 Old 09-04-2012, 07:30 PM
jeepnatv4life
The hell they wont. A full weld is absolutely stronger than stitch welds. I don't know why someone would stitch weld sliders in the first place, you stitch weld thin sheet metal so that you don't burn through or warp it.
if ur weldin2x6 to sheet metal/unibody going from a bunch of little stitch welds to a full on seam WILL NOT change anything because...............ur still welding to sheet metal. SO before you pipe in.....think before you speak
XJ 35's locked Gas Tank in the Trunk Shox Hoops in the rear.
'13 RZR 570
jeepnatv4life is offline
post #290 of 2369 Old 09-04-2012, 07:57 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
X2. Most will advise against fully welding things like frame stiffeners to the unibody. Fully welding are simply not necessary in a lot of scenarios
1990JEEPXJ is offline
post #291 of 2369 Old 09-05-2012, 02:53 PM
Weeder1
How you plannin on bracing the sliders?
-98 xj sport-
http://www.jeepforum.com/forum/f177/weeder1s-xj-build-1391067
Weeder1 is offline
post #292 of 2369 Old 09-05-2012, 06:37 PM Thread Starter
ibjeepin95
With metal . I am going to run three legs per side from the "frame" rail to the slider.... Kinda like this in post #17..... http://www.naxja.org/forum/showthrea...1075717&page=2
post #293 of 2369 Old 09-07-2012, 11:30 AM
Weeder1
I gotcha. Im thinking of running supports out to the bottom of the 2x6 and plating under that to make like a boat side.
-98 xj sport-
Weeder1 is offline
post #294 of 2369 Old 09-07-2012, 01:17 PM
DezertXj88
1990 XJ Cherokee
I was thinking of doing this as well..but at this point why not cut a few more inches up? Like what Eric did on his? Just curious honestly..it seems about the same amount of work either way?
DezertXj88 is offline
post #295 of 2369 Old 09-07-2012, 03:08 PM Thread Starter
ibjeepin95
It's a lot more cutting doing it that way. I will add 2 or 3 legs to mine. Got the metal to do it today.
post #296 of 2369 Old 09-13-2012, 06:02 PM Thread Starter
ibjeepin95
Re-painted my Hyline Hood vents..... still waiting on templates.
post #297 of 2369 Old 09-16-2012, 06:35 AM Thread Starter
ibjeepin95
Got my frame stiffeners on yesterday. I can tell a big difference with them on. I'll get better pics later.
post #298 of 2369 Old 09-16-2012, 06:36 AM Thread Starter
ibjeepin95
Here is another pic I got, showing how bad I need to rebuild the leaf packs and do a shackle relocation....
post #299 of 2369 Old 09-17-2012, 06:00 PM
jeepnatv4life
take some close up pix main
'13 RZR 570
post #300 of 2369 Old 09-17-2012, 06:55 PM Thread Starter
ibjeepin95
I will. They are just like everyone elses haha
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
