ibjeepin95's 99' XJ Build - Page 19 - JeepForum.com
post #271 of 2370 Old 09-02-2012, 11:40 AM Thread Starter
ibjeepin95
Almost forgot, I ordered some HD Offroad stiffeners today!
ibjeepin95 is offline
post #272 of 2370 Old 09-02-2012, 04:50 PM
DezertXj88
1990 XJ Cherokee
Your setup is so sick. What leafs did you end up with again? Stock & a AAL correct? And just a 3" Rustys coil?
DezertXj88 is offline
post #273 of 2370 Old 09-02-2012, 07:33 PM Thread Starter
ibjeepin95
Thanks man! Yup, just a 3 inch AAL with a stock pack and a 3 inch coil. Suspension is still far from done. I still need longer rear shocks, trim the shock mounts on the Dana 30, think I'm staying short arm and going with either Clayton or Rokmen. Also needs a shackle relocation in the rear. Bumpstops and skids are your friends being this low.
post #274 of 2370 Old 09-03-2012, 12:05 AM
DezertXj88
1990 XJ Cherokee
Seems like it, I think 33's will be big enough for me though. 35's seem like alot of extra weight.
post #275 of 2370 Old 09-03-2012, 04:34 AM Thread Starter
ibjeepin95
They aren't as bad as everyone thinks they are...
post #276 of 2370 Old 09-03-2012, 08:49 AM
Weeder1
I just put clayton shorts on my sh*t with te same lift as you, un-fing-believeable dude. Soo nice, i can droop crazy now. I still have two adj short lowers sitting in my garage not being used....
-98 xj sport-
http://www.jeepforum.com/forum/f177/weeder1s-xj-build-1391067
Weeder1 is offline
post #277 of 2370 Old 09-03-2012, 09:08 AM
JJeeper09
If you are interested, I'll sell you my Rokman arms for a good deal. It will motivate me to stretch.
JJeeper09 is offline
post #278 of 2370 Old 09-03-2012, 10:36 AM Thread Starter
ibjeepin95
PM'ed ya. Or text me, whatev.
post #279 of 2370 Old 09-03-2012, 12:26 PM
Motorcharge
Originally Posted by jeepnatv4life
ur info is garbage.......a few more beads wont change anything. do it right now that you know theyve bent. Buy the stiffeners then get some box tube and be done..
The hell they wont. A full weld is absolutely stronger than stitch welds. I don't know why someone would stitch weld sliders in the first place, you stitch weld thin sheet metal so that you don't burn through or warp it.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #280 of 2370 Old 09-03-2012, 12:49 PM
Weeder1
Yo what kinda skids you running? Im thinking about doing a full belly
-98 xj sport-
Weeder1 is offline
post #281 of 2370 Old 09-03-2012, 03:22 PM Thread Starter
ibjeepin95
Sliders and fuel tank right now. Going to build a completely flat crossmember and clock the transfer case very soon.
post #282 of 2370 Old 09-03-2012, 03:23 PM Thread Starter
ibjeepin95
Stitch welded them because it seemed that's what most were doing. I'm going to go back and do some lore welding then brace them.
post #283 of 2370 Old 09-03-2012, 04:03 PM
DezertXj88
1990 XJ Cherokee
I may have a set of currie arms I can sell you bud. Adjustable upper & lowers, JJ on both ends. My buddy had them after he went long arm and idk if he sold them yet or not.
What would you say about 33's vs 35's in terms of weight & stress on the jeep itself? Suspension and sch as well? I've got my WJ steering about to go on, actually just picked up my hubs a few minutes ago lol. So braking & steering won't be a concern!
post #284 of 2370 Old 09-03-2012, 06:08 PM Thread Starter
ibjeepin95
Never ran 33's much but 35's aren't bad as far as power like everyone says. As far as strength goes, at this point I have only broke one shaft on the 30 and that was from losing a u joint cap. I was bouncing the Jeep and getting some wheel spin going so that was the main cause. As you can see in the vid, I have used the skinny pedal a bit and haven't had much of an issue. Just don't think your Jeep is invincible lol. Mad wheel spin on steep climbs and skinny pedal at full lock are the biggest killer of stock shafts I would say.
post #285 of 2370 Old 09-04-2012, 11:08 AM
Brookhart63
Stock D 30's don't like 35s. Especially at full lock.
Bought not Built
Jeep Outdoor Club of Cental Iowa
Square Headlight Jeep Club
Brookhart63 is offline
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
