I want to buy a welder!! - JeepForum.com
post #1 of 8 Old 06-25-2008, 07:00 AM Thread Starter
LeeBee
I've slowly been buying equipment and tools so that I can have welding capability. Now its time to get a decent welder. Any recommendations on what a good buy would be? I'd like to put together a front and rear bumper for my 99 XJ, I also have a trailer that needs some work. Don't want to spend too much money, but I don't want a piece of crap either. Mabye a used mig or tig that stands the test of time?
"Practice technique my friend, and speed will come."
LeeBee is offline
post #2 of 8 Old 06-25-2008, 07:10 AM
00BlackdOut
You can find used MIG welders all the time. My suggestion would be to buy a welder that is capable of running gas. Good brands are Miller & Lincoln(I prefer Lincolns, but it's all preference). If you're going to primarily do flux-core welding, Lincoln developed the system so it's best to run their wire, contact tips, machines, etc. I'd wait on a TIG until you learn how to weld efficiently with another process. TIG is an expensive process, and your cost does not lye solely in the machine. Just my $0.02.
00BlackdOut is offline
post #3 of 8 Old 06-25-2008, 07:32 AM
TheRo0sTer
Ease of use go with Mig. If you don't want to be buy a bulkier 220v welder then invest in a propane torch and buy a 110v. That way when you get into the 1/4" and up you can preheat the welding area. Or you can go big and save time.
I agree with 00Black on the TIG. There are 14 people in my shop of the 14 I'd say 5 are proficient enough to call them TIG welders. It takes lots of practice and cleaning to get nice beads. I've been TIG welding for 18yrs and I didn't become proficient in TIG till 5yrs after I was taught. Positive side of owning a TIG welder, you can weld every weldable material there is with it. Cost goes up with Argon, Cups, Tungsten (multiple diameters), torch parts (caps, collets and collet bodies) and any prep equipment.
Anthony
TheRo0sTer is offline
post #4 of 8 Old 06-25-2008, 07:35 AM Thread Starter
LeeBee
I'm not familiar with gas welders, how do these work? I'm used to the old stick welders. Are the mig's a self fed welder?
LeeBee is offline
post #5 of 8 Old 06-25-2008, 07:42 AM
TheRo0sTer
Mig is self fed with either flux core wire or coverage gas. Both work fine, flux is a little messier than gas. Gas burns hotter.
Anthony
post #6 of 8 Old 06-25-2008, 08:20 AM
jeepnphreak
1989 XJ Cherokee
With flux wire as is burn it created a shield to protect the weld wich later needs to be chisled off as slag just like the old stick method.
the gas mig as mix of argon/co2 is common and protect the weld, there is no slag with gas to be chisled off later.
with flux wire you can weld slightly thicker metals that with gas. The flux wire gets jsut a tad more penetration.
1989 XJ, 5spd, np231 with bjconversion SYE , re3.5, 33x12.5r15 BFgoodrich ATS, D30 F, Dana 44 from 87 with 4.56s, Custom front bumper.
94 yj: stock everything and 4 angry squarrels under the hood.
jeepnphreak is offline
post #7 of 8 Old 06-25-2008, 10:19 AM
hermantherugger
hermantherugger's Avatar
I just bought a Hobart Handler 187 Mig welder. I picked up a bottle of C25 to weld with solid 0.030" wire. It's a nice setup, but I wish I would have saved myself some money, and went with the Hobart Handler 140. Runs on 120V (household power) instead of me running a new outlet to the garage. The outlet wasn't a big deal, but the additional cost of the unit was pretty substantial.
Here's some links to use as a reference. Also, Hobart is made by Miller. It's a great unit.
Here's what I bought - Hobart Handler 187
Here's the 120V unit - Hobart Handler 140
I ended up getting free shipping, and a free welder cart when I ordered from Northern Tool.
'97 Sahara - 8.8 Swap w/ Artec Truss, UCF Tummy Tuck, ZJ V8 Coils & some spacers, 35" Mud Kings, Rokmen Corners, & 2 car seats :)
'93 Wrangler - 2" BDS Springs, MORE Shackles & Body Lift - Sold
'99 Cherokee Sport - 2" OME springs, Trimmed Fenders, Custom Bumpers - Sold
hermantherugger is offline
post #8 of 8 Old 06-25-2008, 12:13 PM
conrasm
conrasm's Avatar
I also have a Hobart 187. Nice unit and has 2 more voltage settings than the Lincoln that Lowes and HD sells. Got mine at tractor supply and paid about $580 after sale and 10% off coupon, which I just got another one in the mail for July 1-13th.
Check out the fabrication section on the forum main page. There's a lot of stuff on welders.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
Welder help Apostle XJ Cherokee Technical Forum 10 09-07-2009 11:52 PM
What welder for a beginner? skenzer XJ Cherokee Technical Forum 23 04-17-2009 04:51 AM
Welder questions JeepMN XJ Cherokee Technical Forum 14 09-02-2007 10:58 PM
would this welder wrk for me? xj5399 XJ Cherokee Technical Forum 21 12-22-2006 04:24 AM
What welder to buy Lore XJ Cherokee Technical Forum 4 11-08-2004 09:52 PM
