I probably already know the answer... - JeepForum.com
post #1 of 5 Old 09-14-2012, 11:56 PM Thread Starter
JeepXJT
In the winter I volunteer taking hospital employees in to work when the snow is bad. I have had some tsrting issues that seem to be more apparent when it is raining. not sure about cold. I need this 91 XJ to be usable at a moments notice. If the cooling system was in tip top shape, In what conditions could the 4.L run for more than 24hrs? fresh oil, freezing temps, a more efficient fan..... what are your thoughts?
JeepXJT is offline
post #2 of 5 Old 09-14-2012, 11:59 PM Thread Starter
JeepXJT
*starting.
JeepXJT is offline
post #3 of 5 Old 09-15-2012, 12:02 AM
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
If everything was in good shape it should run fine until the oil needed changing. There is a team that run a 4.0 Cherokee in the 24 Hours of Lemons race and they keep it on the redline for pretty much the entire race, and take high speed corners which starve the engine of oil at times. All of this being done with a typical 4.0 and they do pretty good for their class.
14JK -
98XJ
Past - 95YJ 99XJ 98XJ 05WK 94XJ
biggn235 is offline
post #4 of 5 Old 09-15-2012, 06:38 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
When's the last time your Jeep got plugs, wires, cap and rotor?
cruiser54 is offline
post #5 of 5 Old 09-15-2012, 06:34 PM Thread Starter
JeepXJT
less than 100 miles on cap rotor plugs wires fuelpump CPS PCM
JeepXJT is offline
Think I know the answer but ... Jeremy_Cherokee XJ Cherokee Technical Forum 5 05-15-2010 01:54 PM
I Have The Answer ErtsRide1 XJ Cherokee Technical Forum 8 10-27-2008 10:22 PM
Answer me this... auto-matik MJ Comanche Technical Forum 28 08-30-2006 05:57 PM
Answer me this yankeeboy XJ Cherokee Technical Forum 4 03-09-2006 02:43 PM
Who can answer this? ronnie67 XJ Cherokee Technical Forum 8 02-23-2006 04:20 AM
