I drive LOTS of Miles. But Want to put 31s on. What to buy to maximize comfort? - JeepForum.com
post #1 of 14 Old 07-30-2014, 06:40 PM Thread Starter
cavalier
So here's the deal. I daily drive my 92xj 4.0 AW4 (3.55 Chrysler 8.25) 75 miles a day. That's a lot of driving. It's ALL highway. Around 80mph (Detroit police don't care). My Jeep now is stock with 215s. And the ride is comfortable, safe, and reliable.
Now, I want to give her a little bit of a lift and some tires. So I bought the kit in the attachment (cost me $290). And I plan to grab some 31s.
My question is this: since I drive so much on the highway, how do I maximize comfort and minimize wear and tear on my suspension. I want this lift to have as little effect on durability/smoothness as possible. I'm fine with a firm ride, but not vibrations/shakes.
What do you recommend? What is not included in this kit that I'll need to make this happen? Thank you all for your time.
cavalier is offline
post #2 of 14 Old 07-30-2014, 07:39 PM
LimeLJ
LimeLJ's Avatar
It says Rough Country. Prepare your butt for the oncoming pain and anything included in that kit should be thrown out. If you really want to use those parts adding a full set of adjustable control arms will help with getting the axles positioned perfectly for a better ride.
Rubicon Express' front drop brackets will put the control arms into a good angle for ride smoothness, but the brackets are designed for 5.5" lifts. A 3" lift is the in between area where getting the control arms at good angles with aftermarket parts is more difficult.
2004 Jeep Wrangler Unlimited
1997 Jeep Comanche - 4.7L Stroker, Lifted, "Restored", and soon to be supercharged.
LimeLJ is offline
post #3 of 14 Old 07-30-2014, 07:41 PM
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
High quality springs/shocks and a shackle relocation kit. You don't need control arm drop brackets.
2016 TJ of the Year
Founder,
EugeneTheTJ is offline
post #4 of 14 Old 07-30-2014, 07:45 PM Thread Starter
cavalier
Hmm. Sounds to me like I didn't think this one through properly.
cavalier is offline
post #5 of 14 Old 07-30-2014, 07:56 PM
EugeneTheTJ
Tar Heel
Yep. I wouldn't install any single item in that kit if a smooth ride is what you're going for.
2016 TJ of the Year
Founder,
post #6 of 14 Old 07-31-2014, 06:23 PM
dillholes
1997 XJ Cherokee
do not listen to the naysayers! i have the exact same set up on my '97 and endure the same bombed out, metro detroit roads as you. i added 2" coil spring spacers up front and dakota bastard pack leafs out back and when everything settled i am at a total of 4.5 inches of lift on true 31" (30.5 inch actual) tires. i would rate my ride quality as firm more so than soft but not painful or uncomfortable. coming from a guy with 2 bad discs in his back you can take it as a fair rating. i can drive 3 or 4 hours on the freeway before i need to stop and stretch. i also pull my 2600# camper once in a while and it works just fine. a few tips...if those shocks are the hydro this or that you need to ditch them, way harsh. i have the rc n2.0 shocks and they are night and day different. much plusher ride quality and still kick azz offroad. bilsteins would be the bomb if you have the cash-got those on my ram and the ride is just silly. i added a durango steering box with a jcr steering box brace. a must have with the bigger tires and mich roads in my opinion. i also added an iro double shear track bar and their hd tie rod as well. tightens up the front end like new.(i also replaced all ball joints,tie rods, wheel bearings, etc with moog parts). i would also look into some adjustable upper control arms just to simplify the caster angle adjustment. (i welded up the holes in my stockers and measured what i needed, and drilled new holes).i did need to add a sye to mine because of the lift but if you stay at the 3" lift you can probably get away with a transfer case drop if you run into vibes. i can set the cruise at 70 on the freeway, turn on the a/c and it goes straight and true and smooth and works just fine. i have ridden in set ups with way more money into them and mine rides, handles, and drives way better. and i get a true 15 to 16 mpg doing it...
I jeep,therefore I am.
dillholes is offline
post #7 of 14 Old 07-31-2014, 07:12 PM
Modstock
Im with this guy. Some of us have better things to throw money at (like house payments and ect).
Your lift is fine and should do the ticket. Ive ran the same lift with no problems and passed friends broken down with 35's on the trail .
Seems like alot of people suffer from "little-man syndrome" if ya catch my drift.
Modstock is offline
post #8 of 14 Old 07-31-2014, 08:47 PM
Nick05
1994 XJ Cherokee
if you are looking for a smoother riding tire, try to find some 16's or 17's with the equivalency of a 31 (i think its 265). you can get them in something a little tamer and smoother since a lot of newer trucks come with them.
Nick05 is online now
post #9 of 14 Old 08-01-2014, 05:33 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
I probably wouldn't go any wider than 9.5" tires for a long distance daily driver.
***Chris***
chris87xj is online now
post #10 of 14 Old 08-01-2014, 06:55 PM
raypla
Oops
99 XJ 4.0 D30 29sp 8.25, IRO TB & HD Tie Rod, Kellys WIP main 5 wires 1AWG
, Banks header, Stainless Magnaflow catback, cat, 2" OME lift, JC1B Leafs, OME sports, JKS discos, 30X9.5X15 BFG AT's, Fastman 62mmTB, Cibie E-codes with 55/60 Osram bulbs, Putco harness=JUNK!!, Alpine 7563 Deck, PWX 10" Cubby, JBL GTI 180.2 400wX1 rms, 6.5 Infinity Perfects , front PWX 6.5, Infinity ref amp 111wX4 rms, Optima Yellow, 100 sqft of
raypla is offline
post #11 of 14 Old 08-01-2014, 07:00 PM
raypla
I been running 30x9.5 for 6+ years, been happy with them. Not all that much less height but much less of a contact patch it keeps your rpm range/rolling resistance more optimum for fuel efficiency. Also easier on the rest of your components as well.
raypla is offline
post #12 of 14 Old 08-02-2014, 07:27 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Check out Kumho KL78 tires. Excellent in the rain and ride smoothly. Cheap, too!!
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #13 of 14 Old 08-03-2014, 01:54 PM
Beards
I drive 72 miles every day. All highway. I also drive 520 miles across the state every other weekend. I have a '96 with a 2" AAL budget lift and Cooper Discoverer 31x10.5. The ride is absolutely perfect and I love it. I can go 90mph over a bump without a single vibration and it drives like butter. The tires are fantastic and have a 55,000 mile warranty. I also get 18mpg at ~80mph.
1996 Cherokee winter daily/funmobile
1991 Civic hatchback summer daily/weekend racer
-best of 11.73 @125mph with full interior and street tires
Beards is offline
post #14 of 14 Old 08-04-2014, 11:30 AM
SSellers
3" lift and Cooper Discoverer A/T3's in 265/75R15 on -19mm offset wheel. Rides as good as it did on stock tires. I've got full leaf packs not AAL's though.
Steiner
1998 XJ Classic driver
1998 XJ Sport spare parts supply
SSellers is offline
