I bought my first Jeep this week, and it's an XJ - Page 15 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > I bought my first Jeep this week, and it's an XJ
Only 2 Days left to win $3,800 Jeep Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention seahawks fans!!! Want to save some $$$ ??!!
Unread 08-13-2014, 01:06 AM   #211
AKIQPilot
AKIQPilot's Avatar
My friend Robbie's 2000 WJ. Took him about 10 days to build start to finish and thats only working on it evenings after work. 4 link front and rear. Full Hydro Steering. 7.17 gears. 1 Tons. 129" wheelbase. His winch is center mounted in the belly pan. It has a quick disconnect thimble so he can run it out front or rear any time he wants to.
Robbie is an animal in this thing. He jumps it every trip out. It really rips.
An '96 on 38.5 Boggers
Found some grass in the swamp.
AKIQPilot is offline   Reply With Quote Quick reply to this message
Unread 08-13-2014, 01:17 AM   #212
AKIQPilot
AKIQPilot's Avatar
I finally got around to installing some rock rails on my beater. hahahaha. Just kidding. They are just tube steps. I bought them for $50 and whacked them up so they would fit with my big tires. They were in perfect condition and fit nice with just a little welding. They are about 36" up from the ground to the step.
Now my wife can get in and out a little easier. She still thinks she wants a stirrup on her side but for now I'm holding off. LOL
I also finished trimming my front fenders at the front.
Unread 08-13-2014, 01:40 AM   #213
DunmerBoy
Desert Explorer
DunmerBoy's Avatar
That's about the only time tube steps hVe ever looked cool haha
We are a group of individuals that worship a box shaped unibody that's been out of production for over 13 years. There's no shame to be had here. :D
COTM October 2014
- Build Thread -
DunmerBoy is offline   Reply With Quote Quick reply to this message
Unread 08-13-2014, 07:48 AM   #214
VegasGT
Rustler of Jimmies
VegasGT's Avatar
Looking great!!!
Whats your wheelbase on that thing?
- '99 XJ Sport -
Lifted, Locked, Stiffened
4.5"/35's
July 2013 COTM
July 2014 COTM
Build Thread
VegasGT is offline   Reply With Quote Quick reply to this message
Unread 08-13-2014, 09:42 AM   #215
AKIQPilot
AKIQPilot's Avatar
Originally Posted by VegasGT
Looking great!!!
My wheel base is 109". About 4" stretch on back and 4" in front.
Unread 08-22-2014, 03:46 PM   #216
AKIQPilot
AKIQPilot's Avatar
I've been wheeling the heck out of my Jeep this past few weeks. I was rolling with the big boys most of the time and we found lots of super deep mud holes and plenty of winching.
Decided it was time to do a little upgrade on my battery and cables. My old battery was fine but it would struggle under a big load after about 1 minute of pulling. I did a bit of research and decided to skip right over the Optima and get a good battery.
X2 Power AMG from Batteries Plus. 880 CCA and 134 minutes of reserve capacity. It uses virgin pure lead and AMG construction. I got the model with top and marine posts so I could add additional cabling without cluttering up the top posts.
I put a new #4 ground terminal from the battery to the block and added another #4 grounding cable from the battery directly to the winch. In addition to that I have the winch grounded directly to the chassis. I also have an additional #4 grounding cable from the battery to the chassis.
I added a #4 charging wire directly from the alternator to the battery. I used the existing #0 power cable from the battery to the winch that I installed last year. Also a hold over from last year is the #2 power wire to the accessory plug on the bumper. The original power wire from the battery to the starter and alternator was in perfect condition so I reused that one.
To some this might be overkill but it's very easy to overlook power and grounds when carrying the very large loads demanded by a winch. Where we go I just can't afford to have an issue.
Unread 08-22-2014, 03:51 PM   #217
AKIQPilot
AKIQPilot's Avatar
The Big Brown Truck dropped these off yesterday too.
Unread 08-22-2014, 05:54 PM   #218
Xride
Air shocks?
Love this thread. Would love to see some pictures of how that center mount winch works.
99 XJ, black, 4x4, NP231, 8.25 rear. Fully locked.
5.5" long arm lift, 31x10.5x15 Runway Enduro M/T
Xride is offline   Reply With Quote Quick reply to this message
Unread 08-22-2014, 06:19 PM   #219
AKIQPilot
AKIQPilot's Avatar
Originally Posted by Xride View Post
Air shocks?
Those are entry level Walker Evans Emulsion shocks. They are filled with nitrogen and shock oil mixed together to provide dampening. They are bolt on shocks W/E offers for TJ, XJ and JK guys. Available in about any length needed.
They are adjustable by varying the nitrogen pressure and the oil volume. And of course you can revalve them as needed to change the dampening.
I will try to get some pictures of the center mounted winch next time I wheel with Robbie.
Unread 08-22-2014, 07:49 PM   #220
VegasGT
Rustler of Jimmies
VegasGT's Avatar
Such good stuff man! Love everything about this build, always look forward to your updates.
- '99 XJ Sport -
4.5"/35's
July 2013 COTM
July 2014 COTM
Build Thread
Unread 09-21-2014, 03:37 PM   #221
AKIQPilot
AKIQPilot's Avatar
Well, for a change of pace I took the roof rack off. What do you guys think?
Unread 09-21-2014, 03:49 PM   #222
Luke95
Needs moar low.
Resident XJ lowlife. 35 general reds on 3inches of lift.
Luke95 is online now   Reply With Quote Quick reply to this message
Unread 09-21-2014, 04:08 PM   #223
AKIQPilot
AKIQPilot's Avatar
Originally Posted by Luke95 View Post
Needs moar low.
Haha. Not sure what that means. If you mean get it lower to the ground thats not really possible without lots of changes. 45" tires don't fit under an XJ very well without hacking it all up. I would have to relocate the battery and airbox to get any lower up front.
Unread 09-21-2014, 06:40 PM   #224
Teej
Do you even Luke95?
Teej's Avatar
Idk those tires are pretty small
Teej's '01 XJ Build Thread
Instagram: @tj_chciuk
CoTM March 2014
Teej is offline   Reply With Quote Quick reply to this message
Unread 09-21-2014, 07:49 PM   #225
AKIQPilot
AKIQPilot's Avatar
For sure. Wish I had 48's.
