I beam MJ - Page 2 - JeepForum.com
post #16 of 25 Old 04-17-2013, 01:15 PM Thread Starter
Steelo805
Originally Posted by Tom95YJ
Above 75mph + west desert of utah + That MJ = Damn good time Do want it Now
Or the desert in southern CA
Steelo805 is offline
post #17 of 25 Old 04-17-2013, 01:16 PM Thread Starter
Steelo805
Originally Posted by prerunner1982
That MJ is on the Foxland motorsports page noted as one of their customers.
If you look at the large image here (http://foxlandmotorsports.com/yahoo_...7.32483202.JPG ) you can clearly see it is a solid rear axle with trailing arm suspension and coil overs.
That's where I found the picture. It's my desktop background currently
post #18 of 25 Old 04-17-2013, 11:58 PM
LimeLJ
LimeLJ's Avatar
If I ever put a roll cage in my MJ I plan on doing that.
LimeLJ is offline
post #19 of 25 Old 04-18-2013, 07:55 AM
haloperformance
1991 XJ Cherokee
Wow... that is Nice
91 XJ: 35"s, 4:56s 5"LA lift 3"stretch, locked, skids, cage, high steer, spray paint.
98 XJ: Stock
haloperformance is offline
post #20 of 25 Old 04-18-2013, 08:01 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
The front setup looks like a Ford TTB.
D3<!L!>3D
S8NNG8 is online now
post #21 of 25 Old 04-18-2013, 08:07 AM Thread Starter
Steelo805
It's an I-beam long travel set up. The 2wd equivalent of a TTB. But it does not require radius arms I believe
Edit: both setups require radius arms.
post #22 of 25 Old 04-18-2013, 11:06 AM
DNFJ
Iirc McNeil racing built that thing years and years ago and it's not solid axle in the rear. I could be wrong, but I'm pretty sure.
You aren't.
It's built for jeepspeed/baja/racing and is IFS up front, ford something or other up front and 4linked rear IIRC. I used to have the specs on it saved because it is my favorite MJ of all time.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #23 of 25 Old 04-18-2013, 04:47 PM
BlueBadger
Originally Posted by VegasGT
I wanna drive it. NAOW.
AGREED!!!!
BlueBadger is offline
post #24 of 25 Old 04-18-2013, 04:50 PM
BlueBadger
Did you guys notice that crazy awesome steering set up?!
post #25 of 25 Old 04-18-2013, 04:57 PM
prerunner1982
1993 XJ Cherokee
Double cross over.
Jon
1993 XJ Sport 2 door 4x4
1997 XJ Sport 4 door 4x2- RIP 6/6/16
2000 XJ Sport 4 door 4x2
prerunner1982 is offline
