HRDCORXJ's 98' "sleeper" build - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > HRDCORXJ's 98' "sleeper" build
Ruffstuff 10 year saleRegear now with Gear Packages from JeepHut.comSmittybilt M1 Fender Flares + FREE Machete
Unread 02-14-2013, 03:46 AM   #76
XJWren
1994 XJ Cherokee
how are the 35's with 4:10s?
94 XJ
91 XJ OLD BUILD! RIP will live on in new jeep!
88 XJ dead!
XJWren is offline   Reply With Quote Quick reply to this message
Unread 02-14-2013, 05:44 AM   #77
ibjeepin95
I'll let him answer for 4;10's but I run 3:55's and its not as bad as everyone makes it to be. I'd rather have 4:88's, but I can deal with what I have for now.
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 02-14-2013, 07:51 AM   #78
HRDCORXJ
They really aren't too bad, but I really want lower I plan on going 4.88 power and mileage are very poor I went from a 16 mpg average and now I'm probably getting 11mpg which is terrible. But I can get it to around 13 if I drive freeway a bunch haha
IG: SHEEPJEEP
HRDCORXJ is offline   Reply With Quote Quick reply to this message
Unread 02-15-2013, 01:02 AM   #79
XJWren
1994 XJ Cherokee
i hear u on that lol i have just swapped some factory 4:10 30/8.25 was at 3:55s its sucks. one day i will get a 44/60 swap done and move up to 37s.
94 XJ
88 XJ dead!
Unread 02-16-2013, 02:07 AM   #80
HRDCORXJ
I'd sure like to have a 44 in the front of mine....
Started on my spring hangers this evening. What a pita it is to cut the old brackets off!
You can see the outer bracket is pulling away. When I lowered jack and let suspension droop both sides bent down and the driverside made some unpleasant pops
Here you can see the crack under the seat
This is the progress thus far. It was tedious cutting the spot welds I used a spot weld cutting bit however it was difficult to get them cut perfect and took some grinding and prying to free the pieces.
IG: SHEEPJEEP
Unread 02-16-2013, 02:39 AM   #81
XJWren
1994 XJ Cherokee
nice job looks good so far
94 XJ
88 XJ dead!
Unread 02-16-2013, 02:41 AM   #82
XJWren
1994 XJ Cherokee
do have a kitty with that mag i have the same one but its dumped and no kitty its starting to get on my nerves.
94 XJ
88 XJ dead!
Unread 02-25-2013, 11:45 PM   #83
HRDCORXJ
Being super lazy with posting as usual...
Took me 4 days to finish my spring hangers kept running into problems with welder and I decided to build some plates to go on the floor to tie the brackets together across the floor. And sandwich them to body for extra strength. And took some time to fix the tears. But got it finished and took it out this weekend! Amazing how much quieter it became after installing the brackets many odd noises disappeared! I am very pleased.
IG: SHEEPJEEP
Unread 02-26-2013, 12:06 AM   #84
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
You went to Little Moab and didn't invite me Shame on you !
Glad that it works well
'89 YJ The Smurf Build Thread
'99 XJ Black Betty Build Thread
Tom95YJ is offline   Reply With Quote Quick reply to this message
Unread 02-26-2013, 12:31 AM   #85
HRDCORXJ
Haha i got bored around 1 yesterday and went for a ride and ended up there! My friend met me there in his yellow xj. It was a goodtime I might go back on Saturday when its warm again!
IG: SHEEPJEEP
Unread 02-26-2013, 09:02 AM   #86
hawaii
I thoroughly enjoy this build thread. Good work done here.
hawaii is offline   Reply With Quote Quick reply to this message
Unread 02-26-2013, 04:47 PM   #87
Weeder1
Bolt the hanger to your plates? Or weld the plates to the floor?
-98 xj sport-
http://www.jeepforum.com/forum/f177/weeder1s-xj-build-1391067
Weeder1 is offline   Reply With Quote Quick reply to this message
Unread 02-26-2013, 05:33 PM   #88
HRDCORXJ
Hangers are welded to the chassis rail and the plates are just bolted. I will pull my carpet up and snap a pic. Thanks Hawaii I appreciate that! Just got pulled over by highway patrolman... Time for flares and flaps again
IG: SHEEPJEEP
Unread 02-26-2013, 05:44 PM   #89
Weeder1
Cool man thanks! They look stout!
-98 xj sport-
Unread 03-05-2013, 09:13 PM   #90
HRDCORXJ
Here's a pic of one of the plates under the seat to give you an idea Weeder. I drilled an additional hole to help the plate sit flat which is where the shiny bolt is. It's now time to prep for jeep safari again.
IG: SHEEPJEEP
