How would you repair this door panel? - JeepForum.com
post #1 of 9 Old 05-26-2011, 04:45 PM Thread Starter
Dukenukemx
1997 XJ Cherokee
I wanna fix this door panel, but I don't wanna make it messy with crazy glue. It looks like it was originally glued on, but I wouldn't know how to keep it on while the glue dries.
How would you fix it? I'm even temped to replace the panel.
Dukenukemx is offline
post #2 of 9 Old 05-26-2011, 05:25 PM
AZ Jeff
2014 JK Wrangler
Take the panel off and femove the armrest piece from the main door panel. Then reattach the skin to the armrest with good contact cement and hold in place with tape until dry. Then reinstall armrest onto panel and panel to door.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 9 Old 05-26-2011, 05:47 PM Thread Starter
Dukenukemx
1997 XJ Cherokee
I think the arm rest is plastic welded to the door panel. I don't remember, as it's been a while since I removed the door panel. I'll take it off tomorrow and have a look at it.
post #4 of 9 Old 05-26-2011, 06:14 PM
lilnapsak
1997 XJ Cherokee
if you need a replacement panel i have all 4 in grey and all 4 in black. pm me if your interested
lilnapsak is offline
post #5 of 9 Old 05-26-2011, 07:01 PM
Bock
I'd just take the thing off. Looks aiight without it.
96 XJ Country White AW4 4*4
If it breaks it just means upgrade
Bock is offline
post #6 of 9 Old 05-26-2011, 07:32 PM
teamskiawa
Just take the door panel off. And glue it on with some clamps. The door panel comes off really easy. A couple screws and some of those things that pull out an pop in. Just give it a firm tug and it comes off. Then disco the window wires and locks. Then disco the door lever rods. Ban good to go. Goodluck
______ooooo
/__l_l_,\____\,___
l_---l_l__l---[ ]llllll[ ]
_.(o)_)__(o)_)--o-)_)
i hope this isnt a major problem if so i hope its cheap
teamskiawa is offline
post #7 of 9 Old 05-27-2011, 12:18 PM
AZ Jeff
2014 JK Wrangler
You can replace the heat staking with screws from the back side.
AZ-Jeff
AZ Jeff is offline
post #8 of 9 Old 09-08-2013, 08:22 AM
burgixxl
1978 CJ7
have it got sombody solved ?
Have the same problem.
burgixxl is offline
post #9 of 9 Old 09-08-2013, 10:30 PM Thread Starter
Dukenukemx
1997 XJ Cherokee
Just an update, cause I saw someone post here, but I did heat the areas with a solder gun and it came out. Used gorilla glue and a lot of clamps to glue it back on. Then put the arm back onto the door panel with solder gun and glue sticks. Looks good now.
Too bad I did this 2 years ago...
97 Jeep Cherokee Sport - Custom cone air, exhaust header, KYB, custom Stereo, 2.5 inch Rear lifted
98 Jeep Grand Cherokee - Custom cone air, exhaust header, KYB
Rocker Panel Repair Bedore XJ Cherokee Technical Forum 5 08-02-2010 02:45 PM
Rocker panel repair in Maine??? 98XJinME XJ Cherokee Technical Forum 1 06-09-2009 09:26 PM
Floor Panel Replacement and Rust Repair XJAce XJ Cherokee Technical Forum 1 11-08-2007 09:54 AM
quarter panel repair racr991 XJ Cherokee Technical Forum 10 10-09-2007 05:54 PM
Rocker Panel Repair Pic Request swanee64 XJ Cherokee Technical Forum 7 09-28-2007 10:41 AM
