how much does a front end allignment usually cost? - JeepForum.com
post #1 of 24 Old 01-11-2010, 03:04 PM Thread Starter
jackdup
i think im finally going to put together my budget boost and im trying to get a total cost for everything. what is an average cost for the allingment? thanks alot guys
jackdup is offline
post #2 of 24 Old 01-11-2010, 03:06 PM
Skaboosh
I got a 4 wheel alignment for $99 bucks lifetime at Firestone complete auto care. They are nation wide and will cover me where ever I go. Usually runs 149 for that but got it on sale.
2006 Jeep Wrangler Unlimited Rubicon 4.0 with a 6 speed hand shaker on 35's with 4" of lift. B.S.M.C.C.E.P.C. #86
Skaboosh is offline
post #3 of 24 Old 01-11-2010, 03:12 PM
Kettles
4 wheel? what is there to align in the back? Or did that include balancing?
Tires Plus I think quoted like 70 or so for a front end alignment, when I got new tires (didn't get the alignment, it didn't really need it). Call a shop, they should be able to tell you over the phone.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #4 of 24 Old 01-11-2010, 03:12 PM
olds442
olds442's Avatar
Usually somewhere around 60 bucks in this area...
Family Wheelin...
Dad- '08 JK Rubicon- Stock, BB and 33s coming
Sister- '07 FJ Cruiser- Rear locker, BFG A/Ts
VT
olds442 is offline
post #5 of 24 Old 01-11-2010, 03:25 PM
Skaboosh
Caster in the rear I believe.
One wheel may be farther forward than the other making you dog track down the road.
Skaboosh is offline
post #6 of 24 Old 01-11-2010, 03:25 PM
keaton
Les Schwab around here will charge about 75 bucks.
My Rigs:
2000 XJ
2003 TJ
keaton is offline
post #7 of 24 Old 01-11-2010, 03:52 PM Thread Starter
jackdup
thanks guys..i will call a shop closer to when i am ready to take it there..i just wanted to get an idea now so i can start counting my moneys!
jackdup is offline
post #8 of 24 Old 01-11-2010, 04:56 PM
RoyalXJ
align it yourself. takes 15mins
you cant adjust rear caster on an xj
RoyalXJ is offline
post #9 of 24 Old 01-11-2010, 05:04 PM Thread Starter
jackdup
[QUOTE=RoyalXJ;8669894]align it yourself. takes 15mins
can you give me some info on doing it myself..what all has to be adjusted with only 2 inches? thanks
jackdup is offline
post #10 of 24 Old 01-11-2010, 05:27 PM
RoyalXJ
search on here. theres write ups
RoyalXJ is offline
post #11 of 24 Old 01-11-2010, 05:29 PM
crem
mine cost 60 bucks at alignment specialties, but really the first time you go wheel it will most likely be put out of alignment. i would do your own as royal said
1992 White (SOLD)
1993 Green (SOLD)
1998 Red XJ - Stock for now
crem is offline
post #12 of 24 Old 01-11-2010, 05:41 PM
Bain98xj
the guy that posted the 4wheel alignment has a 06wrangler
Bain98xj is offline
post #13 of 24 Old 01-11-2010, 05:45 PM
jebmccall
1997 XJ Cherokee
even in a cherokee your rearend can get out of alignment when you lift it. if you use lift blocks and dont have the axle perfectly centered it can make you dog track going down the road. , you could have bent axle which an alignment will tell you. its nice working at firestone life time for me is only 59.99
jebmccall is offline
post #14 of 24 Old 01-11-2010, 05:48 PM
RoyalXJ
yeah but theres no adjustments they can do to get it back like on the TJs.
RoyalXJ is offline
post #15 of 24 Old 01-11-2010, 07:46 PM
jaymartin
I have a BB on my 2000 XJ...I had no issues with my alignment when I did mine. Anything more than a BB I would def recommend taking it in regardless - because your replacing suspension components.
Here is what I did to make sure I didn't need an alignment. Had tires balanced when they were mounted. Get a good street tire pressure setup and see if you notice any pulling. If not get 200 miles or so on it and make sure your tires are waring evenly and you'll be set. I saw no reason to take it in and have not had any issues since. 5000 miles ago... No cupping or uneven wear. Good Luck!
2003 TJ 4X4 SPORT, 3" OME, 33x12.5 BFG KM2's
|OlllllO|
2000 XJ 4X4 SPORT, 2" RE BB, 30x9.5 BFG KM2's
|lllll|
jaymartin is offline
Why do front Axles cost more than rear? CharlieMopps XJ Cherokee Technical Forum 7 12-12-2008 01:47 PM
Cost of Front Axle U Joint jeepnick XJ Cherokee Technical Forum 1 06-11-2008 12:10 PM
Front TC Yoke cost? GRDCHRKE555 XJ Cherokee Technical Forum 1 01-12-2008 01:19 PM
front suspension sway??? cost??? andrew.huber@mu XJ Cherokee Technical Forum 2 10-20-2007 04:47 PM
Front Diff Overhaul cost? Spenzin XJ Cherokee Technical Forum 1 07-10-2007 05:18 PM
