How many miles on your Original 4.0L I6 ?? - JeepForum.com
post #1 of 406 Old 07-28-2009, 07:14 AM Thread Starter
Katmandu
How many miles are on your Original (NOT rebuilt) 4.0L I6 ??
How many miles are these engines rated at ?
I know it's VERY subjective (based on regular maintainence and care) but how long do they last ?
Katmandu is offline
post #2 of 406 Old 07-28-2009, 07:26 AM
99Greenmachine
110k miles on mine....I've seen 300,000 some of em
They're pretty durable if you keep up with the maintenance
'99 XJ Sport
Thank You Hooligan!!!
[SIZE="4"]XJ Dana 44, Yukon 4.56 D44 Gears, LeBaron hood vents for sale
99Greenmachine is offline
post #3 of 406 Old 07-28-2009, 07:30 AM
SparkyB
1988 FSJ Wagoneer
My 92 turned 300k a few weeks ago. Still doesn't burn oil and get an average 21 mpg.
79 CJ5
88 Grand Wagoneer
SparkyB is offline
post #4 of 406 Old 07-28-2009, 07:40 AM
_Trucker
'Bigger Member'
_Trucker's Avatar
1989 XJ Cherokee
5154983035.2 cm....
wouldn't be XJ Tech forum if we didn't have at least 3 of this same thread pop up every week.
Thom
NAXJA member # 3388
_Trucker is offline
post #5 of 406 Old 07-28-2009, 07:42 AM
foggybottombob
197K so far
foggybottombob is offline
post #6 of 406 Old 07-28-2009, 08:01 AM
conrasm
conrasm's Avatar
183,xxx on my 94. Still runs good. No major engine work, just water pump, starter, cooling system... The usual stuff that wears out.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #7 of 406 Old 07-28-2009, 08:22 AM
Magus2727
1995 XJ Cherokee
A quick search will complete your needs....
But to answer question, .866 369 154 Light Seconds...
For your conversion:
1 light second = 186,282.02449 mile's
NAXJA Member #2619
1995 Jeep Sport Cherokee 4x4 with an Auto and 4.0L
B&M Transmission Cooler and Autometer Tranny Temp Gauge, Ruff Stuff Diff Cover on D30.
Taraflex 1.5" BB (rear shackle only), HD Quadratec leaf springs, RE 3.5" front springs, OME Long shocks, JKS Adjustable Track Bar from K.O.R.
Daystar Control Arm Bushings, Bushwhacker Flairs, Rhino lining along bottom trim, AGR PS pump with Cooler & Filter.
Bored TB, APN Manifold, New Downpipe, Magnaflow High Flow Cat, Flowmaster Super 44.
Dual Oil Relocation Kit running two K&N301 size filters, Autometer Digital Cobalt Oil Temp and Oil Pressure Gauge.
Magus2727 is offline
post #8 of 406 Old 07-28-2009, 08:26 AM
danw77
1994 ZJ
9,511,983,360 inches on my 99.
my 95 had 14,832,576,000 inches.
i don't know why i just thought of this, but look at it from this perspective: if every inch i had driven in my 95 represented $1, that would only add up to 0.1% of the national debt. now THATS scary.
1983 CJ7 & 1998 ZJ
Hello, my name is Dan, and I have a Jeep problem.
danw77 is offline
post #9 of 406 Old 07-28-2009, 08:26 AM
XJMuscle98
211k so far.
1998 Jeep Cherokee 4.0L AW4/NP231 211k+
"Approximately 80 percent of our air pollution stems from hydrocarbons released by vegetation, so let's not go overboard in setting and enforcing tough emission standards from man-made sources."
Ronald Reagan
My goal is to have 20 lights around my XJ.
Currently: 10
XJMuscle98 is offline
post #10 of 406 Old 07-28-2009, 08:27 AM
dok1313
226,000 give or take.
1999 XJ w/4.5 inch lift, 33" Procomp X-Terrain, Skyjacker double disco's, Steel front bumper with hitch receiver
2001 WJ w/30" Hercules Terra Trac, Pretty much stock. Already have a toy, why change a good thing?
dok1313 is offline
post #11 of 406 Old 07-28-2009, 08:29 AM
93 Cherokee
My 93 has 279k!!
93 Cherokee is offline
post #12 of 406 Old 07-28-2009, 08:37 AM
R5ROD
1989 XJ Cherokee
My 89 XJ has 237,xxx. no major repairs.
R5ROD is offline
post #13 of 406 Old 07-28-2009, 08:40 AM
j_dynomite
3.53E11 mm.....depending on your mechanical abilities, how well you keep everything maintained, and some luck they can run without major problems for a very long time.
j_dynomite is offline
post #14 of 406 Old 07-28-2009, 08:56 AM
90si
my 98 has 280,xxx and is still balls strong
90si is offline
post #15 of 406 Old 07-28-2009, 09:36 AM
jersey_jim
jersey_jim's Avatar
1994 XJ Cherokee
my 94 had 227k my 95 has 115k and my 99 has 198k
94 xj - 5.5" rubucon express long arm, 4.56's, shafted & Detroit locked on 35's
jersey_jim is offline
1999 Orange Cherokee Pics posted 33k original miles 350zmarty XJ Cherokee Technical Forum 10 12-13-2009 04:23 AM
1999 xj 33k original miles 350zmarty XJ Cherokee Technical Forum 26 12-11-2009 02:23 PM
Just bought a 1996 Jeep Cherokee with 51k original miles! Some Questions... wick001 XJ Cherokee Technical Forum 10 05-13-2008 10:53 AM
Original ALTERNATOR, 194 thousand miles. 4.0H.O.XJ XJ Cherokee Technical Forum 10 07-27-2007 06:26 AM
original equipment jaredakleiman XJ Cherokee Technical Forum 2 06-25-2005 07:28 PM
