How loud should the AC compressor be? - JeepForum.com
post #1 of 6 Old 08-20-2011, 08:29 PM Thread Starter
DerMeister
Hey guys, I recently got a new AC compressor and a new accumulator. Then it was vacuumed and charged, as well as oiled.
Now the clutch engages, and the compressor seems to cycle properly, however it is somewhat loud when accelerating at lower speeds.
Its basically just a whirring noise. Hasn't gotten worse, or better over 2 months.
Is this normal?
DerMeister is offline
post #2 of 6 Old 08-21-2011, 11:37 PM Thread Starter
DerMeister
Anyone?
post #3 of 6 Old 08-22-2011, 01:30 AM
jeepdavetj
1991 XJ Cherokee
Any moisture contamination in there? I am not an expert, but I would take it back to where they did the work, unless you did the work. Then I would take it back to you and demand an explanation.
I don't blame people for their mistakes, but I do expect they pay for them.
Ash from Army of Darkness
Alright you Primitive Screwheads, listen up! You see this? This... is my boomstick! The twelve-gauge double-barreled Remington. S-Mart's top of the line. You can find this in the sporting goods department. That's right, this sweet baby was made in Grand Rapids, Michigan. Retails for about a hundred and nine, ninety five. It's got a walnut stock, cobalt blue steel, and a hair trigger. That's right. Shop smart. Shop S-Mart. You got that?
jeepdavetj is offline
post #4 of 6 Old 08-22-2011, 12:44 PM Thread Starter
DerMeister
I did the work minus the vacuum, oiling and refridgerant. I just dont remember it sounding so loud. How would i verify water contamination?
post #5 of 6 Old 08-22-2011, 03:47 PM
jeepdavetj
1991 XJ Cherokee
I am not sure, I know AC shops should be able to check. Not a HVAC guy here, but run it by a shop and ask their opinion. Hell, they may check it for free.
post #6 of 6 Old 08-22-2011, 09:12 PM Thread Starter
DerMeister
Thank you for your help though, I appreciate it. I'll probably post this over at NAXJA and see if I get any bites. If it is deemed a problem or I get no responses ill be headed to a shop.
Loud LOUD Bang after 4WD was disengaged.. abuttino XJ Cherokee Technical Forum 7 07-08-2011 07:50 AM
loud idle, loud under accel!!!! G_baller XJ Cherokee Technical Forum 1 05-26-2009 01:59 PM
Loud Squeal & Loud Leaf Springs XxpeditionxJ XJ Cherokee Technical Forum 3 03-20-2008 07:19 AM
Compressor loud and rattles MattS XJ Cherokee Technical Forum 3 06-13-2005 05:42 PM
'00 XJ Problem - A/C - Loud groaning from compressor? Hellspawn XJ Cherokee Technical Forum 1 04-19-2004 10:30 PM
