How hard would ut be to add .5 of an inch - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > How hard would ut be to add .5 of an inch
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 07-29-2011, 01:48 AM   #1
Joshharris98xj
I am on a skyjacker 2.5 inch lift shackles and spacers how hard would it be to add .5 of an inch?
Joshharris98xj is offline   Reply With Quote Quick reply to this message
Unread 07-29-2011, 08:26 AM   #2
donthelegend
Difficult since you are achieving your current lift with the best ways to add a half inch of lift. Awful difficult to make it it to 3" of lift without springs since shackles and spacers max out at 2-2.5" of lift.
Depending on what your current setup is now, you could add an extra stock isolator to the front for an extra 1/2" there, but I'm not sure what to tell you about the back. Blocks are generally frowned upon since the stock leaf packs are so weak, and your existing shackle would probably add even more stress to the equation.
donthelegend is offline   Reply With Quote Quick reply to this message
Unread 07-29-2011, 11:01 AM   #3
JeepXJMike20
an .5 of inch of lift wouldnt be worth the hassle to add. man if your going to lift higher just go 3.5"-4.5" lift height then it be worth the hassle.
JeepXJMike20 is offline   Reply With Quote Quick reply to this message
Unread 07-29-2011, 03:19 PM   #4
Joshharris98xj
Well I think the perfect lift for me now would be 3" with 33s or 31s because I need allll the gas milage I can get out of it
Unread 07-29-2011, 03:21 PM   #5
donthelegend
then you want 31s, which I think will clear on 2.5"
Unread 07-29-2011, 03:23 PM   #6
Joshharris98xj
They will I'm trimming it up today
Unread 07-29-2011, 03:37 PM   #7
Mark-96-XJ
i had the same thing. the left was 1/2 inch higher. very easy fix, take a overload spring (the bottom one) and put it under the current one, if you have one. that should add 1/2 an inch
[CENTER][COLOR="White"]1999 XJ Classic, Auto, Power everything, 3 inch, GY Wrangler Radial 31's [/COLOR][/CENTER]
[CENTER][COLOR="Green"]1996 XJ 5 Speed, 100% Herculined, Rough country 4.5, BFG A/T 33's[/COLOR][/CENTER]
[CENTER][COLOR="DarkRed"]2012 Honda Ruckus, Stock for now, 114 MPG, Daily Rider[/COLOR][/CENTER]
[CENTER][URL="http://www.jeepforum.com/forum/f22/marks-highschool-build-slow-1068542/"][COLOR="Red"]96' Build[/COLOR][/URL][/CENTER]
Mark-96-XJ is offline   Reply With Quote Quick reply to this message
Unread 07-29-2011, 10:50 PM   #8
Joshharris98xj
What would I do for the front
Unread 07-30-2011, 12:04 AM   #9
EricsXJ
The Post man
EricsXJ's Avatar
Add another coil spring isolator. They measure about 3/4".
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website - EricsXJ.com
EricsXJ is offline   Reply With Quote Quick reply to this message
Unread 07-30-2011, 01:50 AM   #10
Joshharris98xj
Just put it on top of the one I have now? Ha sorry for the noob question
Unread 07-30-2011, 11:07 PM   #11
EricsXJ
The Post man
EricsXJ's Avatar
Yes you can stack them or use them just as you would a coil spacer.
Eric
