Finally got my lift. All i'm missing now is new rear leaf spring shackles. I'm not sure i want to run the stock ones, but at the same time, if I go with too much lift, i'll have to run small tires for a little while, and that will definitely look a little funny. I've got 235/75's right now, and wont be able to upgrade to 31/10.50's for a while still. So my question is new shackles? (adjustable) Or just keep the stock ones for now, then shackle and spacer when i'm ready to upgrade? (advice?)
Also, not sure if i'm going to need a new track bar yet or not. I will eventually upgrade. Will go with a full HD steering set up sooner or later. But not sure if I need one now or not.
Here's the lift: New 3" full leaf packs (not pictured) with rubber bushings and 4 degree shims installed already. New U-bolts, 3" coils, front brake line relocation tabs/brackets, new lower control arms, sway bar drop brackets, and new sway bars, track bar relocation bracket, Pro Comp ES3000 shocks, shock boots, and JKS front lower bar pin eliminators. (already have the rears installed.)
Only problem is now, I'm gonna have to wait for two weeks before I can install it.
I live in an apartment, and wont have access to a garage till then. It sucks owning a Jeep, and not having regular access to my tools and a garage.
I will of course do a full pictured write up when i do the install. i'm anxious to hear some feed back, and even more anxious to get this lift on! Anybody in the Portland Oregon area willing to help out?
