Quantcast Hood Vent Ideas.....I Need Em - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Non-Technical Forum > Hood Vent Ideas.....I Need Em
GR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Old 07-28-2009, 08:48 AM   #46
BRad704
Nothing to see here...
BRad704's Avatar
Originally Posted by DunerDude View Post
I have a 3" hole in my cowl where I plan to run my intake tube next week, It has been 90*+ here in portland, Or for the past week and I have not noticed any decrease in underhood temps. Heat rises just go with vents.
I was talking about actually opening up the black plastic 'screen' also... I would think your case would be really bad on pulling fumes and heat into the interior!
Good point though...
Originally Posted by Jungle Recon
*** this quote has been removed by BRad, in order to maintain the level of maturity that is required in an online forum of one's peers.
BRad704 is offline   Reply With Quote
Old 07-28-2009, 02:00 PM   #47
1984XJ
1990 XJ Cherokee
Originally Posted by 4hrs2Moab View Post
just take your hood off show the world your "goodies"
Then id get oil all over my windshield
.,_______.o_o.
//_|__l__,\___\,___
l_--\__\__l----[]llllll[]
_(o)_)____(o)_)--o)_)
Daily Driver Jeep #16
Utah Jeep'n
1984XJ is offline   Reply With Quote
Old 07-28-2009, 09:34 PM   #48
DunerDude
no fumes, no smell, AC works just as good, nothing has changed. Your saying take off that black screen attached to the cowl vent to get better airflow?
Thats like breathing through a chicken wire fence, wouldn't make a difference if it was there or not haha.
DunerDude is offline   Reply With Quote
Old 07-29-2009, 12:43 AM   #49
GregB_00XJ
GregB_00XJ's Avatar
The right hand side of the XJ cowl "screen" or grille is solid, as in no holes. The drivers side is the vent and it draws air from the left to the right through an opening.
Just saying...
2000 Jeep Cherokee Classic
1992 M101 CDN2 1/4 Ton Off-road Trailer. 90% Daily Driver 100% Fun!
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline   Reply With Quote
Old 07-29-2009, 07:53 AM   #50
RockRodHooligan
Under Construction
RockRodHooligan's Avatar
1989 MJ Comanche
....But if you open up the mesh part on the passenger side of the cowl, then it will rain down the intake hole for the HVAC and leak water into the floor boards.
Penis inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
I seen a frog once that ate a rolypoly that locked onto it's tongue and I rescued it from starvation by removing the rolypoly.
RockRodHooligan is offline   Reply With Quote
Old 07-29-2009, 11:00 PM   #51
DunerDude
exactly, and what would you be acomplishing by removing the screen? reduce cowl area temps?
anywho....
When you put the long louvers (i.e. gen-rights) on your hood, they go over the "frame" of the hood correct? stupid question, but do you cut through it or not?
Old 07-30-2009, 09:20 AM   #52
dcorn
Got mine in. Run Cool medium sized, didn't hit any of the hood supports during the install.
FOR SALE 1998 Cherokee Classic - White
5" lift - 35" tires - locked/geared/shafted/armored
2012 Subaru WRX Limited
dcorn is offline   Reply With Quote
Glock Forum
