hood scoop? vent? BOTH?! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > hood scoop? vent? BOTH?!
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Hey Guys - Extreme Terrain Jeep Outfitters - ExtremeTerraiThe Original 3/8" Ruffstuff Diff Cover!
Unread 04-10-2015, 09:58 PM   #1
andrij13
I'm sure there's probably a thread on this somewhere, but i didn't bother to look. so don't be mad.
so, as i'm sure you all know, xjs run hot.
i tried driving by just pulling the hood lever, but thats squeaky, and i'm not sure its effective.
i've considered buying one of those cheap hood scoops from autozone, and placing it over the head/intake manifold.
i've also thought about vents, from a lebaron or such, and then i've thought about scoop on drivers side, vent on the other for better ventilation.
but i'm not sure.
do any of you guys have any combination of these, and if so, please post pics, and any writeup tips, and tell if its efficient or not.
i'm leaning towards the hood scoop idea, as i see it being a 2 birds with one stone deal. it in theory would scoop in colder air, but also vent while at idle, or driving slow, or when off.
thanks guys.
andrij13 is offline   Reply With Quote Quick reply to this message
Unread 04-11-2015, 01:02 AM   #2
workwagon
When you say you tried pulling the hood lever are you saying your driving around with your hood partially open?... That's probably not a good idea or maybe I just read that wrong
workwagon is offline   Reply With Quote Quick reply to this message
Unread 04-11-2015, 07:03 AM   #3
FairlanePhil
http://www.bing.com/images/search?q=...nt&FORM=HDRSC2
Current: 99XJ 6.5 lift-Bought 2015
Sold: Patriot Blue 00 XJ.
'sploded: 01 stock-0331 head victim
FairlanePhil is offline   Reply With Quote Quick reply to this message
Unread 04-11-2015, 09:58 AM   #4
mschi772
1997 XJ Cherokee
What a compelling explanation for why you couldn't be bothered to look around first despite admitting that you suspect the info you seek is already out there for the taking. No, I won't be mad. You've convinced me thoroughly.
Sent from my phone.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is online now   Reply With Quote Quick reply to this message
Unread 04-11-2015, 12:50 PM   #5
andrij13
yea, the other day, i parked, and popped the hood from inside. then went out to the front. heat was billowing out, so i thought, "hey, ill pop the hood while driving, and maybe get some air flow."
Unread 04-11-2015, 12:52 PM   #6
andrij13
Sent from my phone.
i'm glad
i did look after i posted... haven't seen much of anything but arguing about scoops/vents/cowls
Unread 04-11-2015, 12:58 PM   #7
nolanbalzarini
i have these, they are from hyline. deff. more expensive than some home brew kits, but IMHO it is worth every penny
its got louvers that go one way for low speed cooling, and louvers that go the other way for high speed "ram air effect"
nolanbalzarini is offline   Reply With Quote Quick reply to this message
Unread 04-11-2015, 06:01 PM   #8
andrij13
thanks for the pics!
while the autozone scoop would be cheap, i wouldn't mind spending money on some nice vents or something. i just want to find the right option...
so how do these louvers that you bought work... is it a considerable difference??
Unread 04-11-2015, 09:16 PM   #9
nolanbalzarini
on the temp gauge it never gets over 210, but thats regulated by the thermostat, and on winter mornings it takes way longer for the heater to get hot. At a stop light you can see the heat waves pouring out.
it doesn't drop injector #3 on hot days
and it looks BA!
lower under hood temps are always better than higher temps
Unread 04-12-2015, 07:07 AM   #10
mschi772
1997 XJ Cherokee
Those are nice vents, but I don't fully understand the purpose of the forward-facing vents in the rear. So they'll theoretically scoop air at speed, but why, and why there? All the air entering the engine bay should be entering through the radiator--I see no need to force a bunch of extra air in from above. They also look like a rust nightmare waiting to happen since there is so much hood left trapped under the vent. I'd much rather seem the redesign them to only vent air out and only have vents in the areas of the hood that can actually be cut.
Unread 04-12-2015, 07:14 AM   #11
mschi772
1997 XJ Cherokee
OP, you could always go with a McNeil Racing hood.
Unread 04-12-2015, 12:10 PM   #12
andrij13
yes please!
BUT... that doesnt look finished... is that just a mock up, or do they actually sell them with slots and mesh where there should be?
Unread 04-12-2015, 12:36 PM   #13
mschi772
1997 XJ Cherokee
It's fiberglass. I don't know if they do any more than you see. I've always imagined you just cut out the holes you want to use yourself, but I'm just guessing. Ask them.
Sent from my phone.
Unread 04-12-2015, 12:52 PM   #14
andrij13
kinda pointless to not have it finished... for the money you're spending...
Unread 04-12-2015, 01:52 PM   #15
mschi772
1997 XJ Cherokee
Well, like I said, that's just my guess. I think it's a fine price, and if they do indeed send it out that way, it allows the end user to customize which vents get used; maybe some people don't want them all open. My fiberglass subwoofer box I'm having fabricated will end-up costing about the same as that hood and is smaller and (potentially) simpler.
Sent from my phone.
