Hi lift jack placement - JeepForum.com
post #1 of 13 Old 06-28-2008, 12:39 PM Thread Starter
xvxbigpappaxvx
Hey,
I have an XJ. IF I were to use a hilift jack on my truck where would I place it?
I know the front bumper is flimsy....So where?
ANd I have a hitch on the back so that makes it easy...
Thanks
Jordan
xvxbigpappaxvx is offline
post #2 of 13 Old 06-28-2008, 04:27 PM
EricsXJ
The Post man
EricsXJ's Avatar
Looks like that is about it unless you have rock rails or real bumpers.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #3 of 13 Old 06-28-2008, 04:50 PM
xjpilot
xjpilot's Avatar
you can spend a few bucks and get the wheel straps. That way your jacking distance will be cut in half too.
my jeep has the confused prerunner syndrome....4.5" in the rear and 2" in the front.
Purple Jeep Club Member # 1
xjpilot is offline
post #4 of 13 Old 06-28-2008, 04:52 PM
TwistedcaB-
1991 XJ Cherokee
Edit:
missundestood
TwistedcaB industries
1991 XJ. 8" lift, 35" BFG KM2's. the new project
1990 XJ. 6.5 lift, 33" BFG ATKO's. SOLD : (
TwistedcaB- is offline
post #5 of 13 Old 06-28-2008, 05:00 PM
xjpilot
xjpilot's Avatar
I think he's asking where would he jack from......but I've been wrong before.
xjpilot is offline
post #6 of 13 Old 06-28-2008, 05:39 PM
TwistedcaB-
1991 XJ Cherokee
ooh ok i get it now. haha sorry. but the bumpers are pleny strong enough to jack from. but try and get close to the mounts for the strongest point.
post #7 of 13 Old 06-28-2008, 07:45 PM Thread Starter
xvxbigpappaxvx
I think Im just gunna buy a warn class 3 hitch for the front. It will act as a good jacking point
post #8 of 13 Old 06-28-2008, 07:48 PM
EricsXJ
The Post man
EricsXJ's Avatar
Just an FYI - those don't always work if you have aftermarket wheels. On my last trail ride, a guy in our group got high-centered and tried to use the strap attachment for the wheels. His wheels had less backspacing than stock and because of that the "block" that fits on the jack was pushing against the sidewall and causing the bead to separate expelling air from the tire. I guess we could have used it but we'd have to deal with a flat tire after we jacked it up.
Eric
My website -
EricsXJ is offline
post #9 of 13 Old 06-28-2008, 07:50 PM
EricsXJ
The Post man
EricsXJ's Avatar
You have a lot of faith in thin-gauge sheetmetal. That's all I'll say about that.
Eric
My website -
EricsXJ is offline
post #10 of 13 Old 06-28-2008, 10:12 PM
XJLI
XJLI's Avatar
1993 XJ Cherokee
I've jacked from the stock bumpers and they'll bend, but hold. i will admit it was a scary situation, but i had no other choice in that situation though.
Factory Four Link
XJLI is offline
post #11 of 13 Old 06-29-2008, 12:30 AM
srmitchell
Buy some rails.
Done.
I work on Mopars
srmitchell is offline
post #12 of 13 Old 06-29-2008, 01:26 AM
TwistedcaB-
1991 XJ Cherokee
idk i bet they will bend sometimes but in my experiances they dont even budge. but maybe im just lucky haha
post #13 of 13 Old 07-01-2008, 12:18 AM
XJ2000
XJ2000's Avatar
I personally wouldn't use a hi-lift on stock bumpers. Hi-lifts can be dangerous if used incorrectly, and I think that jacking by a stock bump adds to the potential for a dangerous situation, plus you'll end up messing up your stock bumpers and giving yourself another thing to fix.
Keep a good bottle jack with you, it'll be easier for changing tires.
: 2000 XJ w/ 4.5" RE SF, Locked XJ D44 Rear, Locked D30, and a bunch of other things
Pavement Pounder: 2001 XJ Daily Driver, 2" BB, 245/70R16 AT's on Moabs
XJ2000 is offline
2" Lift, no rear sway bar...should i be nervous on a jack lift Topgun514 XJ Cherokee Technical Forum 4 04-18-2011 12:46 PM
Removing Front LCA Question.. Jack Placement gtospeeding XJ Cherokee Technical Forum 12 09-21-2009 08:05 PM
High Lift Jack (farmers Jack) Jacking points pocquet MJ Comanche Technical Forum 10 03-16-2009 09:16 PM
Jack Stand Placement (8" LA Lift) aero3685 XJ Cherokee Technical Forum 13 03-12-2009 08:18 AM
Jack stand placement Putttn XJ Cherokee Technical Forum 4 01-04-2009 07:01 PM
