Help wiring fog lights... - JeepForum.com
post #1 of 16 Old 04-11-2011, 09:50 AM Thread Starter
docrich52
I just picked up some sweet orange foggers with glass lenses off of an old isuzu trooper froat the junk yard this past weekend. I had to sand prime and paint them this past weekend and when i took them apart, the insides were crazy rusted so i had to cut the wires from the bulbs and do away with the garbage wires that i pulled of the trooper. with my zero experience in electrical work, can anyone assist me in wiring these babys up? they have a 12v 55w bulb.
docrich52 is offline
post #2 of 16 Old 04-11-2011, 11:38 AM
AoA
1997 XJ Cherokee
what exactly don't you know how to do with these lights?
You'll fine me chasing the Sun!
97' XJ 7" of lift 33's - Still Running Strong
97' XJ 5" of lift 33's - Sold
93' ZJ 4"of lift, 31's - Totaled
AoA is offline
post #3 of 16 Old 04-11-2011, 12:14 PM Thread Starter
docrich52
I want to be able to run my fog lights whenever i flip the switch. with that being said, i bought a kit at auto zone that came with wires and a switch but no relay...
will the kit work by itsself or should i get a relay and go that route. i have a few wiring diagrams that are simple enough to follow but im not sure what to buy wire and relay and switch wise if i need to get something else.
I want to do it right the first time and for it to last as long as possible and be functional.
post #4 of 16 Old 04-11-2011, 04:42 PM
AoA
1997 XJ Cherokee
IMO relays are alot of extra work for nothing, i run mine with wires and a inline fuse
AoA is offline
post #5 of 16 Old 04-11-2011, 06:00 PM
lostissues
1987 MJ Comanche
relays are a good thing to have. it allows for shorter run of higher power wires. you can use a relay to have the power go from the battery through the relay to the lights instead of from the battery across the engine bay, through the firewall, to a switch, back through the firewall, across the engine bay and down to the lights. also less wire to worry about it possibly chaffing, melting, grounding out, getting caught in moving parts.
just search the electrical and 2 way forum for "fog lights" or "fog light installation" "fog light wiring" and there will be a ton of threads on how to wire it up properly with a relay.
lostissues is offline
post #6 of 16 Old 04-11-2011, 06:49 PM
AoA
1997 XJ Cherokee
thats allot of extra work for something he doesnt want, he wants to flip a switch and thats it. if you wire it right the first time with a good gauge wiring, all this "melting, grounding, chaffing" won't happen.
AoA is offline
post #7 of 16 Old 04-11-2011, 07:45 PM
lostissues
1987 MJ Comanche
well with a relay all you have to do is flip a switch and it works, and you don't have to run higher current wiring as long of a distance. But you did answer first so every person who answers after that must be an idiot. to the op, just ask over in the electrical part of the forum how to wire up the lights and people will probably post up a picture of a circuit using a relay and tell you that is probably the best way to go about it.
actually here is Jerry Bransford's (mod for the electrical forum and a very knowledgeable person when it comes to wiring) answer on how to wire up off road lights (fogs are the same principle)
http://www.jeepforum.com/forum/f20/w.../#post10420644
post #8 of 16 Old 04-11-2011, 07:47 PM
Spokes
if u want them on anytime ur head lights come on than just wire them into your head lights lol
Red 00 XJ lifted
Build -->
Blue 00 XJ Hella stock
"Lima bean" 91 XJ 5spd
Spokes is offline
post #9 of 16 Old 04-11-2011, 08:01 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Use a relay and use a fuse. Fuses and relays prevent fires.
CJ7-Tim is offline
post #10 of 16 Old 04-11-2011, 08:05 PM
AoA
1997 XJ Cherokee
your calling me an idiot?
your kidding right? I did all 8 of my 100w spots this way and the correct way, no half *** jerry rigged ****. I've had no problems at all, no to mention he's only running 55w so theres not much draw at all to have a need for a relay.
AoA is offline
post #11 of 16 Old 04-11-2011, 08:13 PM
Nick
2006 WK
2001 WJ | 4.7L V8 |
Hemi Club Member 60
1990 White XJ Laredo [Sold]
2000 Silverstone XJ Classic [Sold]
2006 Dodge Charger RT Hemi [Sold]
2001 Jeep Grand Cherokee [Current]
Xbox Live gamertag: XJ Nickk
Originally Posted by DcMuff View Post
Banned for being the cooler Nick
Nick is offline
post #12 of 16 Old 04-11-2011, 08:36 PM
lostissues
1987 MJ Comanche
I actually never called you and idiot. there was probably a little kidding somewhere in my post. And I didn't say that not using a relay would not work. and just because you did it that way does not make it correct, or the only definitive way to wire lights in.
here is a hella light kit http://www.quadratec.com/products/97008_0002.htm
it uses 2 55 watt bulbs and includes a RELAY to wire it up.
here is an IPF kit
http://www.quadratec.com/products/97017_1502.htm
here is another 55 watt kit with RELAY.
http://www.quadratec.com/products/97016_60.htm
another
http://www.quadratec.com/products/97016_00.htm
and one more, although I'm sure there are a lot more.
and I am done with this thread because I will not argue with someone over the internet, you know what they say about that
so OP, I hope that you have gotten enough information to help your situation, or at least a little more info on where to get more information. good luck with your install.
post #13 of 16 Old 04-11-2011, 08:39 PM
lostissues
1987 MJ Comanche
post #14 of 16 Old 04-11-2011, 08:42 PM
mongo1991
1991 XJ Cherokee
yeah just get a three prong switch top to the battery with a in line fuse middle goes to the hot side of the lights bottom to a ground then ground out the grounds on the lights took me all of 30 min to do it all man
mongo1991 is offline
post #15 of 16 Old 04-11-2011, 09:17 PM
AoA
1997 XJ Cherokee
here is an IPF kit
another
lmao, i think its funny that some 130w KC kits dont come with a a relay at all.
oh well, its mostly personal preference, but if your gunna half *** it at least use a relay hahahaha.
AoA is offline
Wiring in fog lights geewally9 XJ Cherokee Technical Forum 12 08-16-2013 08:16 PM
wiring up fog lights?? natedawg87317 XJ Cherokee Technical Forum 9 12-17-2006 01:29 PM
wiring lights help T4STE XJ Cherokee Technical Forum 3 12-13-2006 08:24 PM
wiring for lights prestoncsu86 XJ Cherokee Technical Forum 1 02-04-2005 10:17 PM
Wiring fog lights using factory wiring... DavesXJ XJ Cherokee Technical Forum 5 01-11-2004 08:22 AM
