Quantcast Help me with my setup! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Non-Technical Forum > Help me with my setup!
Free Shipping on TIRES at KrawlOff-RoadGenuine Italian leather shift boots for your Jeep!Rough Country Deals at JeepHut.com
Old 02-08-2010, 04:41 PM   #1
GTEIS300
Hi! Im pretty new to this 4x4 world so I am looking for some help. I have lived in the performance world for sometime and I am picking up an XJ for a fun daily driver. At THIS moment in time I dont have plans to adventure onto extreme trails. Dont quite need a monster yet
Im trying to setup my XJ for typical trails for camping, light exploring, and make my way through snow. Im tired of my 2dr daily and want something I can toss the dogs in and not have to worry.
Im trying to figure out a good suspension setup for my need but there are so freakin many options out there. Ive found a few setups pictures I like but not sure on what would work for what I need. There is so many variable that can change the ride height it seems.
Here is a few pictures I found:
I like black
So I guess my question is what do I need? I was trying to find a 2" BB kit but couldnt really find any. Next was the Rough County 3" Kit. Lastly is tires. Im lost with these.
Anyways thanks for the help!
GTEIS300 is offline   Reply With Quote
Old 02-08-2010, 04:43 PM   #2
GTEIS300
Even this one looks decent.
I think this one is stock height just with larger wheels?
Old 02-08-2010, 05:30 PM   #3
billabongopblue
Looks like you are looking in the 2-3" range. Which is the best way without some major modifications. Also in the 30-31" tire range.
For 3" I suggest Rough Country and would make sure you go with a full leaf setup as it is worth it for the extra money.
For 2", i would make sure your leafs are in adequate shape for a Add A leaf, or shackle. Best yet would be a bastard pack. Then some coil spacers up front.
For tires, it really depends on what you are looking to do, and as a daily driver it seems a good all terrain tire is what you need. BFGoodrich All Terrain are among the most popular. Also some wheels in the 15x8 with 4" backspacing would fit you wheel.
Try some searching on lifts, and you will see a lot of this repeated over and over! Good Luck!
96 Classic - 3" Lift - 31" BFG AT's - 29 spline 8.25 - 4.10's - Tow Hooks - RE track bar - RC Dif Guard - Cowl Intake - LeBaron Vents - Dynomax Catback - IRO H&T
billabongopblue is offline   Reply With Quote
Old 02-08-2010, 05:31 PM   #4
Apostle
depends on budget. what i would recommend is try to find a jack and lift the jeep. figure out how high you like it, then measure from the center of the wheel to the bottom of the flare. think 17" is stock. you have to not imagine your wimpy tires there, just the height
2011 JK Wrangler - Sahara Tan SOLD
2012 JKU - White
Apostle is offline   Reply With Quote
Old 02-08-2010, 05:50 PM   #5
Mighty Thor
Just another option. You can skip the lift initially and open up the fenderwells and add new fender flares for about the same money. An advantage is that you don't change any suspension geometry and so don't usually encounter any of the occasional suspension issues that go along with lifts etc. Road stability is not changed substantially and you can still add tire size to get a little more ground clearance.
Stock Jeeps are pretty capable and my nephew can drive his stock Grand Cherokee right behind my lifted XJ on many of our outings. The primary reason for lift is to add tire size and that is usually to get the body higher up over rocks and similar obstacles. If you open the wheel wells up and get the bigger tires on you may find you have all you want. If you later decide to add lift, you may find that you can go with a smaller and thus less expensive lift to clear the tires you want.
Mighty Thor is offline   Reply With Quote
Old 02-08-2010, 06:24 PM   #6
GTEIS300
Thanks. Ive been looking at the Lift Setup thread over and over.
Thanks. This is something I have not heard of. This maybe my best route. I dont need a monster, quite yet. Just something to get me over the snow and take me on some trail for camping, hiking, and biking.
Old 02-08-2010, 06:40 PM   #7
Jeep89JV
Bastard Pack(search it) with a set of tires that fit your needs.
From how you're speaking on your needs i'd run a set of BFG Ats or Goodyear Duratracs with a set of 4" bs rims. Chop your fenders if you're willing to and then eventually you'll be comfortable and look to go higher.
[B][I]If you don't stand behind our troops, feel free to stand in front of them.[/I][/B]
[I][B]My Build Thread:[/B][/I][url]http://www.jeepforum.com/forum/f177/broke-kid-build-96-xj-1007038/[/url]
[B][I]New Mexico Driving Rules...[/I][/B][LIST][*]As a general rule, the vehicle most in need of a significant amount of bodywork (for which the driver is most likely uninsured) always has the right of way.[*]Never use directional signals when changing lanes. They only serve to give away your next move, causing most NM drivers to speed up and not let you in. In fact, use of directional signals within most large NM city limits is actual illegal.[*]NM law states that at least 50% of all paved surfaces within the state must be under construction at any one time. In all construction zones, at least half of the available lanes must be closed, regardless of whether any actual construction is be accomplished or not. Construction signs shall be regularly repositioned in order to warn drivers about upcoming lane closures immediately after they pass the last exit before traffic backups.
[*]Driving through constructions zones with upcoming lane closures is a popular game in NM. It’s called the "speed up and pass as many cars as you can, then see how close to the lane closure you can squeeze back into traffic before hitting any of the orange construction barrels" game.[/LIST]
Jeep89JV is offline   Reply With Quote
Old 02-08-2010, 06:42 PM   #8
GTEIS300
Chopping fenders shouldnt be a problem. Ill check out the bastard pack. Thanks
Old 02-08-2010, 07:49 PM   #9
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
If you have the money for it, I would just go with a nice 3" lift and a set of 31" tires. If you go with a set of steel wheels they are cheap and 15x8 with 4" backspacing will look good with that set-up. The rough country 3" kit is pretty nice. Rubicon express makes a 2" budget boost with a full length add-a-leaf and spacers along with new shocks. This will work nice with 30" tires. If your leafs are in good shape then you will be okay using a full length add-a-leaf. Just steer clear of the short AAL's they will sag quickly and give a rough ride.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Old 02-08-2010, 07:51 PM   #10
GTEIS300
Im leaning towards this setup, unless the Jeep I pick up is already lifted... Yea I havent even bought one yet and I got the bug.. Yes..its that bad..dont laugh.
Old 02-08-2010, 07:58 PM   #11
303_XJ
I got the 'bug' and am surprised my wife hasnt left me yet because of it For all holidays including Valentines Day I ask for Jeep parts. She hates it.
Definitely check out Rough Country, the customer service there is awesome
Colorado Jeep Club Member # 208
303_XJ is offline   Reply With Quote
Old 02-08-2010, 09:03 PM   #12
Spokes
decent?!?!?! lol thats my jeep... stock height on 235 definity dakota m/ts.... this is how it sits now, i added a RC series 2 3" lift.
60Th Ann. Ed. Wheels For Sale Mint Condition! PM Me!
http://newjersey.craigslist.org/pts/2813005727.html2000
Red XJ, lifted with tiny tires... for now
Build --> http://www.jeepforum.com/forum/f177/better-redder-build-thread-1280981/
Spokes is online now   Reply With Quote
Old 02-08-2010, 09:06 PM   #13
GTEIS300
Haha.Looks very good. How do you like the lift?
Old 02-08-2010, 09:09 PM   #14
Spokes
thanks! and i love the lift! it rides A LOT better, when i bought my jeep it had heavy duty shocks on it so it rode like a mack truck. now its just a littler stiffer than a stock xj. but i also run my tires at 35psi (highway max cold setting) so im sure that stiffens it up a little. i would deffinatly buy this lift again.
Old 02-08-2010, 09:10 PM   #15
GTEIS300
Good to know! The Jeep I have picked out has a lift currently but I am waiting for the owner to get back to me.
Glock Forum
