Help with lift and tires - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Help with lift and tires
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueBlack Friday SALE! Up to 20% off at Diode Dynamics!
Unread 11-16-2014, 04:14 PM   #1
ridewithme93
Hi everyone, I just purchased a 1995 XJ with a 3 inch skyjacker lift and 30 inch tires. I am looking to upgrade to 33 inch tires. I will be purchasing the Rough Country 4.5" X-Series Long Arm Suspension Lift Kit with Performance 2.2 Series Shocks and Rear Leaf Springs http://www.jeep4x4center.com/rough-c...s-rc-p686.html
and am wondering what else I will need to purchase to complete the lift and put on the 33 tires? I am planning on using the rims I have now for the 33s. Anything else I need to pick up to make the transition go as quick and smoothly as possible? Thank you in advanced!
ridewithme93 is offline   Reply With Quote Quick reply to this message
Unread 11-16-2014, 04:17 PM   #2
ridewithme93
also i failed to mention the tires will be 33 by 12.5
Unread 11-17-2014, 08:23 AM   #3
amerbritcan
4.5" is plenty of lift for 33's. Careful of the backspacing of your wheels fitting 12.5's you may need to space out your wheels some.
amerbritcan is offline   Reply With Quote Quick reply to this message
Unread 11-21-2014, 02:23 PM   #4
indeepwithajeep
Also don't over look extending your bump stops when putting on larger tires.
indeepwithajeep is offline   Reply With Quote Quick reply to this message
Unread 11-21-2014, 04:26 PM   #5
rugsucka
Pick up an angle grinder and expect to use it if you plan on disconnecting and wheeling with 33's.
You will rub due to the size of the wheel well opening.
Unless you bumpstop pretty much all of your uptravel.
'00 XJ - Somewhat modified
'01 Venture - high mileage, paid for, shut it
rugsucka is offline   Reply With Quote Quick reply to this message
