HELP! Im at a loss with my cherokee - JeepForum.com
post #1 of 8 Old 05-07-2013, 09:21 AM Thread Starter
Stegs
just brought my "weak" battery to 3 different places to have it tested
they all said my battery is fine. about 70%
But here is the thing, my jeep leaves me stranded just about after every drive i make
and when i do get stranded, i cant jump start my jeep...it doesnt do anything
5-10 min later my jeep will start up like nothing happened
When i turn the key, it just clicks, as if my battery is 100% dead. but the lights are on inside, radio works, power windows work
help guys before i sell this thing off to someone looking for a project
Stegs is offline
post #2 of 8 Old 05-07-2013, 09:49 AM
freestylekid33
Try putting it in nuetral then starting.. Sounds like bad connection or nuetral safety switch?
freestylekid33 is offline
post #3 of 8 Old 05-07-2013, 10:16 AM
DNFJ
Neutral Safety Switch or Starter dying out.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #4 of 8 Old 05-07-2013, 03:31 PM
Muddy97Cherokee
1997 XJ Cherokee
Check your terminals on the battery. Just move then around and try to make good contact with the post on the battery. More than likely the terminals are corroded and just need to be cleaned.
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
Muddy97Cherokee is offline
post #5 of 8 Old 05-07-2013, 03:56 PM
Orvis97
I second cleaning the terminals, I was having similar symptoms on my ZJ and all it ended up being was corrosion on the battery terminals and battery cables.
2005 TJ Rubicon - 6" Rough Country Long Arm Lift, 35x12.50 Falcon Wild Peak A/T, Body Armor Rockcrawler Side Guards, MOPAR Rock Crawler Winch Bumper, ENGO E9000 Winch, Body Armor Boly in Cage - Mine
1998 Grand Cherokee - Daily Driver/tow rig - 2" BB, 31x10.50 A/T's - nothing special
2012 Grand Cherokee - Wife's ride
2010 JK Unlimited - stock - Wife's Ride! - SOLD
1997 Grand Cherokee Orvis V8 ------ 2.25" BB - SOLD!
Orvis97 is offline
post #6 of 8 Old 05-08-2013, 05:29 AM Thread Starter
Stegs
little review
clean battery cables and terminals
when i pull the battery out and re-install it, the jeep will start fine
if i leave it sit for about a hour, when i turn the key all I hear is "click, click" etc
A few weeks ago, my jeep would turn over but it wouldnt fire...thats when the shop started blaming my battery
now its sits dead in my garage, all the power windows work, radio works etc...
just hear click when i turn the key
cherokeeforum suggest bad starter, but when i pull the battery out and re-install it turns over like normal, no issues ever
totally lost as to where to go from here...
Stegs is offline
post #7 of 8 Old 05-08-2013, 06:56 AM
DNFJ
Put the key on the on position
Climb under and jump the starter with a screw driver
Does it still click or does it immediately fire up? If it fires up fine, probably ignition coil.
Previous:
DNFJ is offline
post #8 of 8 Old 05-08-2013, 10:55 AM
98muddyjeep
rockin lil red wagon
98muddyjeep's Avatar
I would start checking the wires and cables to the battery and starter,I have seen it before the wires break down inside the housing and will work cold but put voltage through em for a few minutes to heat them up and they fail.
ah,beer the cause of and cure to all of lifes problems ...Homer J Simpson... I am the guy in the red jeep!
98muddyjeep is offline
