Help! Breaks pulling to the right - JeepForum.com
post #1 of 8 Old 07-16-2011, 06:43 PM Thread Starter
Joshharris98xj
Just replaced right and left breaks and rotors bled them and when I break it is pulling to the right?
Joshharris98xj is offline
post #2 of 8 Old 07-16-2011, 06:46 PM
youngjeepguy
Did you clean both rotors with brake cleaner? If you did you may need to bleed the left side.
youngjeepguy is offline
post #3 of 8 Old 07-16-2011, 06:53 PM Thread Starter
Joshharris98xj
Did both and just discovered my frount right tire is low on air I'm pumping it up is that it?
post #4 of 8 Old 07-16-2011, 07:35 PM Thread Starter
Joshharris98xj
Hahaha sorry it was the air in my tire I feel like a retard it took me about and hour or two to figure this out
post #5 of 8 Old 07-17-2011, 12:13 AM
youngjeepguy
glad it was an easy fix, and don't feel to bad its a common problem.
post #6 of 8 Old 07-17-2011, 12:26 AM
Flyordie
1985 XJ Cherokee
heh. Only time mine pulls either way is it depends on which way the road is sloped or which way my steering wheel is turned to.
Used to pull very much to the left though until I rebuilt my passenger side brake caliper. Cheaper than buying a whole new caliper. lol.
I keep my tire pressures a little higher on the right side than my left to counter the slope in the road though.
Flyordie is offline
post #7 of 8 Old 07-17-2011, 12:29 AM Thread Starter
Joshharris98xj
Ha thumbs up
post #8 of 8 Old 07-31-2011, 10:45 AM
david92xj
1992 XJ Cherokee
glad to hear it was an easy fix, the same thing happened to me, but i found out my caliper was frozen
david92xj is offline
