Heim Joint Steering - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Heim Joint Steering
ANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete NEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDJeep Wrangler Complete Gear Upgrade Kits with Installs and
Unread 11-04-2014, 07:52 AM   #1
Bmjames24
Heim Joint Steering
I'm sort of in a bind with my steering ATM. I've got my eye on a 3/4" heim steering kit from RuffStuff.com
My question is steering geometry. I see a bunch of guys having to relocate their trackbar mount to keep with the same degree as the drag link. I'd like to know if I could just snag the kit and just do my drag link and tie rod and be okay with my upgraded adjustable track bar?
Bmjames24 is offline   Reply With Quote Quick reply to this message
Unread 11-04-2014, 12:09 PM   #2
1990JEEPXJ
1990 XJ Cherokee
You'd be fine. You'll notice some bump steer but your jeep will not be unsafe to drive. The tie rod will interfere with the trackbar bracket a tiny bit though
My POS
1990JEEPXJ is offline   Reply With Quote Quick reply to this message
Unread 11-04-2014, 01:13 PM   #3
VegasGT
VegasGT's Avatar
Im in the same predicament. I was just going to run the tie rod UTK and drag link OTK, but mount it to the top of the pitman arm rather than below it. Angles will be near identical to factory.
Like this:
- '99 XJ Sport -
Lifted, Locked, Stiffened
4.5"/35's
July 2013 COTM
July 2014 COTM
Build Thread
VegasGT is online now   Reply With Quote Quick reply to this message
Unread 11-04-2014, 04:12 PM   #4
Luke95
I run it the way vegas shows.
I drive inbetween a gentle crawler to a full blown rock bouncer.
My total carnage from that total is
1 HPD30
1 ZJ steering setup
1 Xj steering setup
2 AW4s.
2 flex plates.
Motor mounts
Trans mounts.
1 set of stock uppers.
1 set of lower control arm bushings.
This setup has been the best that I have ever ran, it will do 100 down the highway (with a major tail wind)
Totally worth it man.
Resident XJ lowlife. 35 general reds on 3inches of lift.
Luke95 is offline   Reply With Quote Quick reply to this message
Unread 11-04-2014, 04:27 PM   #5
Bmjames24
1 HPD30
1 ZJ steering setup
1 Xj steering setup
2 AW4s.
2 flex plates.
Motor mounts
Trans mounts.
Is that just a regular heim kit? All I was able to see in your pic was your drag link otk and tie rod utk and was your drag on top the pitman or under? Also what kit are you running. I'm kinda sketching out on joint quality if I get this on kit from Ruffstuff. Comes with 54" of DOM and 4 heim joints.
http://www.ruffstuffspecialties.com/...g/34STEER.html
Unread 11-04-2014, 04:29 PM   #6
Luke95
Ruffstuff 7/8ths kit.
I am OTK On my Draglink and it is mounted above the pitman.
Tie rod is UTK
Unread 11-04-2014, 04:40 PM   #7
Bmjames24
Tie rod is UTK
Stock knuckles still right? No high steer? N how well are your joints doing? I don't want to be replacing joints frequently.
Also did you have to bore out the knuckles to quite a bit? I don't want to bore out the knuckle to an unsafe diameter.
Unread 11-04-2014, 04:54 PM   #8
Luke95
Bronco Dana 44.....
I drilled the pitman and it went fine. No high steer. I don't have from lol!
Unread 11-04-2014, 05:06 PM   #9
Bmjames24
Bronco Dana 44.....
Well that doesn't help me. Lol I still got a HPD30 lol I guess I'll be okay running the 3/4" for a good while on the d30
Unread 11-04-2014, 06:08 PM   #10
VegasGT
VegasGT's Avatar
I plan to run the 3/4" kit. Not real comfortable drilling the knuckles out far enough to accept 7/8's heims.
- '99 XJ Sport -
4.5"/35's
July 2013 COTM
July 2014 COTM
Build Thread
Unread 11-04-2014, 06:30 PM   #11
Bmjames24
Yeah neither do I. Plus the 3/4" kit will hold 35s no problem and that's as big a tire as I plan to move up to on my d30
Unread 11-04-2014, 06:50 PM   #12
Luke95
I was telling you my experience lol. And showing how if is setup.
Unread 11-04-2014, 07:02 PM   #13
Spokes
Mall Crawler
Spokes's Avatar
HAHA JK Luke, I plan on going with the 3/4" kit soon also.. but i dont have stock knuckles. I know lots of people running the 3/4" kit and they have no problems.
just so you know heims arent legal in steering in most state FYI...
Red 00 XJ lifted
Build -->http://www.jeepforum.com/forum/f177/...hread-1280981/
Blue 00 XJ Hella stock
"Lima bean" 91 XJ 5spd
Spokes is offline   Reply With Quote Quick reply to this message
Unread 11-04-2014, 09:46 PM   #14
rugsucka
98% of cops wouldn't know a heim joint if it lodged itself in their arse.
Use safety washers and get used to noisier steering and you'll be fine.
'00 XJ - Somewhat modified
'01 Venture - high mileage, paid for, shut it
rugsucka is offline   Reply With Quote Quick reply to this message
Unread 11-04-2014, 10:38 PM   #15
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
I'd agree, but they will when you go to get the inspection to renew your tags.
Then again, I might know a guy that knows a guy that doesn't care if you have cats on your exhaust if ya know what I mean...........just sayin......
~Mike~
My Build Thread WK
My Other Build Thread XJ
'01 XJ with some stuff
Sept 2013 Cherokee of the Month
'07 WK with some other stuff
~RED WK CLUB #7~
'11 KK with mostly stock stuff
'06WK our first Jeep with stock stuff - totalled and gone
JeepN4KC is online now   Reply With Quote Quick reply to this message
