headliner replacement 2001 XJ Sport - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > headliner replacement 2001 XJ Sport
RIGID LED Light Blowout Sale - All Sizes, All Series, all Magnaflow SS Cat Back Exhaust System, Street, High ClearanJeep Long Arm Upgrade Kits on SALE for as low as $649.95 S
Unread 02-12-2015, 02:40 PM   #1
ziajeep
How technical does replacing the headliner get? I am beginner rookie all the way. Done a few fixes on my 01 Sport 2x4 but would like to attempt headliner if it's significantly cheaper than a quick shop visit.
Otherwise, anyone in Houston, TX area have a good shop recommendation?
Thanks for the advice!
ziajeep is offline   Reply With Quote Quick reply to this message
Unread 02-12-2015, 06:23 PM   #2
XJ2Timer
http://www.jeepforum.com/forum/f11/h...eduex-1778554/
http://www.jeepforum.com/forum/f11/u...mbers-1523096/
1st one- 1989 Cherokee Laredo. 12 great years
2nd one- 2001 Cherokee Limited. Got it before they were gone.
XJ2Timer is offline   Reply With Quote Quick reply to this message
Unread 02-13-2015, 08:21 AM   #3
2000_XJ_MI
Pull it out, pull the fabric, scrub off the adhesive/leftover fuzz, spray it with bedliner, re-install it.
2000_XJ_MI is offline   Reply With Quote Quick reply to this message
Unread 02-19-2015, 07:12 PM   #4
ziajeep
Thanks 2000_XJ_MI and XJ2Timer! That useful links forum is awesome, thanks for pointing me in that direction!
Unread 02-20-2015, 11:01 AM   #5
bobthecatkiller
Iv heard of people having someone do it for $150 but my quote from my local shop was $386 HA so for me its significantly cheaper. Not sure of the diy cost but the fabric nnd adhesive can't be much.
"****, I might **** around and bring the Jeep back No doors on it, flexin' with the seat back"
bobthecatkiller is offline   Reply With Quote Quick reply to this message
Unread 02-22-2015, 11:01 PM   #6
Tagg
Headliner Replacement
I just did 2 XJ headliner replacements in the past 6 months. The cost was about $ 70.00 each for materials and glue. Items where purchased from Joann Fabrics stores.
Tagg is offline   Reply With Quote Quick reply to this message
Unread 02-23-2015, 05:10 AM   #7
jeepjunkie97
Make sure to go rather heavy with the adhesive. First time I put some 3m super 77 on, it was clear but wasn't enough, put it so it looked like a dusting of snow and it stuck pretty dang good. Don't be afraid to let it sit and stick over night. Just don't put it in your room because it will smell like adhesive for a week
jeepjunkie97 is offline   Reply With Quote Quick reply to this message
Unread 02-23-2015, 06:26 AM   #8
2000_XJ_MI
The trick with most spray adhesives is to coat both surfaces that are to be "mated" before installation. This allows the adhesive to cure to each part before putting them together.
The directions are pretty clear on the good name brands...3M for example.
Unread 02-23-2015, 12:18 PM   #9
jeepkid03
Winning
jeepkid03's Avatar
Doing the headliner is pretty straight forward. Don't spray it with bed liner though as another person mentioned.
I bought some fabric for mine from Teamcherokee.com they had the right color and length so I only had to trim it a little bit.
You can do it in an afternoon if you take your time. You just have to unbolt all the trim pieces, unbolt the visors, and pull out the headliner. Then just scrape off the old stuff, spray on some glue, apply the new fabric and re-install.
-Josh
My 0331 Head Swap How-To Thread:
http://www.jeepforum.com/forum/f11/0...hread-1371398/
Build Thread:
http://www.jeepforum.com/forum/f22/m...build-1119997/
jeepkid03 is online now   Reply With Quote Quick reply to this message
