Headliner questions - Page 4 - JeepForum.com
post #46 of 99 Old 04-24-2014, 11:33 AM
bluejunior
bluejunior's Avatar
Originally Posted by XJkid01 View Post
How much did you get your roll on for and how much did you use
I found a herculiner roll-on kit for $75ish +tax at a store. It came with a gallon, a brush and two rollers. I used a little more than half the gallon to do two coats. So if you've got rollers sitting around just buy a couple pints. I also picked up a rattle-can for like $8 to do the speaker grilles and lights.
Wasn't MUCH cheaper than having it done, but it was easy and I didn't want to have to take it to a shop, it was more about the time than the money for me.
Lifted, Locked, Stiffened
bluejunior is offline
post #47 of 99 Old 04-26-2014, 09:00 AM Thread Starter
XJkid01
That's probably what I'll do but since I have some plasti dip that's what I'll use on the speaker grills and lights
XJkid01 is offline
post #48 of 99 Old 04-27-2014, 01:45 PM
troydg
Originally Posted by lawsonr71
I didn't notice any noise difference. It's not like our XJ's are the quietest anyway. I did line the roof with some adhesive aluminum flashing I got a Lowes. It is almost the same thing as Dynamat, but at a fraction of the cost. Here are a few pics. I did my headliner in black because it matches my trim, but for a few extra dollars they can color match.
I love the camo you have!
troydg is offline
post #49 of 99 Old 04-27-2014, 09:00 PM
citRon
2003 KJ Liberty
Originally Posted by mjonesjr View Post
You can get headliner fabric at any good local fabric shop. Locally I can get the headliner material for around $3 a yard. By the time I buy a couple cans of good 3M adhesive, I'd have around $35-$40 in the material. Then it only is a matter of time to do it.
$3 a yard is awesome! The only place around here that carries it wants $16 a yard!
1996 Cherokee Country 4x4
citRon is offline
post #50 of 99 Old 04-29-2014, 03:16 PM
bobbo_xj
The roll-on sounds like a good choice plus you have spare paint. I JUST finished spray painting mine with rust-oleum's truck bed coating, on top of rust-oleum primer (Filler/Primer). One can of the filler/primer is not enough and the fiber lines of the board still transferred somewhat through 3 cans worth of the bedliner spray paint. My spray painting skills are not great so results are a touch blotchy but still satisfied.
If I had to do it again I would do a roll on application. But I think with 2 cans of 11oz primer/filler and 4 cans of 15oz spray can bedliner you can get decent results if you are ok at spray painting. FWIW, based on bluejunior's paint usage my estimate is near the same volume of total paint (82oz vs. say 5/8ths of a gallon? -80oz). So you might be able to save money by using more primer than bedliner spray? IDK about the results.
BTW I also taped 12 feet of 16inch of double bubble reflectix ($8 worth), loosely fitted under the metal roof. My air conditioner can use all the help it can get.
2001 XJ Sport, 176k mi.
bobbo_xj is offline
post #51 of 99 Old 04-29-2014, 07:38 PM
lawsonr71
2007 WK
Thanks. It's Multicam.
2001 XJ Sport 4x4, 4.0, 2007 WK Overland 5.7 QDII Light Greystone Pearlcoat (Wife's Jeep)
lawsonr71 is offline
post #52 of 99 Old 04-30-2014, 02:38 PM
bluejunior
bluejunior's Avatar
Originally Posted by bobbo_xj View Post
The roll-on sounds like a good choice plus you have spare paint. I JUST finished spray painting mine with rust-oleum's truck bed coating, over a can worth of rust-oleum primer (Filler/Primer). One can of the filler/primer is not enough and the fiber lines of the board still transferred somewhat through 3 cans worth of the bedliner spray paint. My spray painting skills are not great so results are a touch blotchy but still satisfied.
It's worth mentioning that the roll-on herculiner came out much more heavily textured (if I owned a camera I'd post a pick, but my smartphone's out of commission right now) than the spray-on job originally posted. None of the fiber lines came through, but it's knobby not smooth.
post #53 of 99 Old 04-30-2014, 04:08 PM
jeepjunkie97
Maybe if you sanded it with a finer grit it would smooth it some?
jeepjunkie97 is offline
post #54 of 99 Old 05-03-2014, 12:08 AM
bluejunior
bluejunior's Avatar
I like ot fine as is, I just thought I'd give a heads up to anyone reading and considering using that brand.
post #55 of 99 Old 05-09-2014, 05:47 PM Thread Starter
XJkid01
I just bought the herculiner kit. Tomorrow I'll get it all rolled on
XJkid01 is offline
post #56 of 99 Old 05-10-2014, 11:31 AM Thread Starter
XJkid01
How do you take the lights off the headliner board? Do I just brute it off???
XJkid01 is offline
post #57 of 99 Old 05-10-2014, 12:07 PM
jeepjunkie97
Take the plastic lens off and look for a screw or under te bulb? Not exactly sure though just my suggestion
post #58 of 99 Old 05-10-2014, 12:11 PM
PaYankee
No,
For 97+ take the middle light cover off to access the screws that hold the fixture in place. Same for front and back.
For 97-Take off the plastic light cover off then you have to get those stupid tabs off with a needle nose. Same for front and back. Quite the pita.
99 xj 2wd/94xj 4wd np231 3lift
PaYankee is offline
post #59 of 99 Old 05-10-2014, 12:48 PM Thread Starter
XJkid01
Originally Posted by PaYankee View Post
No,
What about the seat belts in the back?
XJkid01 is offline
post #60 of 99 Old 05-10-2014, 01:45 PM
bluejunior
bluejunior's Avatar
Just a big torx bolt
