Headliner fabric question - JeepForum.com
post #1 of 7 Old 06-13-2013, 11:21 PM Thread Starter
gnarlyxcharlie
Redid my visors, now all I have left is my soundbar and headliner. However, I have this giant thin black sheet I would like to use, but was told the glue would seep through the sheet and it would be visible? Should I even bother trying it or no?
gnarlyxcharlie is offline
post #2 of 7 Old 06-14-2013, 08:36 AM
LAjeep
2007 WK
Planning on redoing mine soon too. Are you planning on using a bedsheet as headliner? I would only imagine that glue would definately show through that.
2007 GC Limited 2WD Hemi
LAjeep is offline
post #3 of 7 Old 06-14-2013, 10:56 AM
greenlawnjeeper
I replaced the headliner in another vehicle using "Joanne's" headliner fabric and "specific" headliner spray glue. Make sure you use specific headliner glue otherwise it won't stay stuck.
'96 Cherokee Country, Magnaflow cat and Borla exhaust, Hella 550's, Up Country suspension, Michelin MS 2's in 235x15 and Edelbrock IAS shocks. 91K orig. miles - the wife uses it ('cept when I borrow it to go huntin').
greenlawnjeeper is offline
post #4 of 7 Old 06-14-2013, 12:24 PM
jdjonesdr
The headliner spray contact cement that I've seen comes out of the can almost like a mist.
If that's the case, as long as you do 3-4 really light coats about 5 minutes apart or so, you should get a nice coat that won't show through.
Just remember to practice laying it on without cement a few times before you attempt the real thing. Once that stuff touches, it's stuck!!
DOMINICAN STORM RIDERS JEEP CLUB, SD,RD, Member #1, 1990 Cherokee, 4.2, Autmatic, A/C, Stock.
It's my seventh jeep, had em' all my life, did all my 4 wheelin' on sand dunes.
My jeep loves me.. right?
jdjonesdr is offline
post #5 of 7 Old 06-16-2013, 12:43 PM Thread Starter
gnarlyxcharlie
Yep, time to go get a headliner from a junkyard. Sprayed the headliner and sprayed the sheet, went to lay the sheet back down and a gust of wind blew through my garage. Looks awful
post #6 of 7 Old 06-16-2013, 01:34 PM
greenlawnjeeper
You need 2 people to do it - you and an assistant. I did mine in the "Living room."
post #7 of 7 Old 06-16-2013, 02:16 PM
Motorcharge
Go to any local dealerships part's department and buy a couple cans of CRC Healiner Spray. Spray the whole board and the back of the fabric down and let it set up for about 10 minutes before putting them together. The glue won't seep through that way.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
