headlights - JeepForum.com
post #1 of 20 Old 07-14-2017, 05:45 PM Thread Starter
lazaro99
Xj headlights
looking for some budget friendly headlights the stock ones suck as everyone knows i have a 96 xj let me know whats out there
lazaro99 is online now
post #2 of 20 Old 07-14-2017, 06:45 PM
imthehink
imthehink's Avatar
I ran this setup for years, literally night and day difference!
Housings:
http://www.ebay.com/itm/Hella-003427...BYWjME&vxp=mtr
Bulbs:
http://www.ebay.com/itm/Hella-H4-100...ZXabkg&vxp=mtr
Relay/Harness:
http://www.ebay.com/itm/Ceramic-H4-9...xTrhqt&vxp=mtr
1999 XJ
4.5" BDS and Stuff.
imthehink is offline
post #3 of 20 Old 07-15-2017, 07:49 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Best bang for the buck is the harness.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #4 of 20 Old 07-15-2017, 08:11 AM
mschi772
1997 XJ Cherokee
Please see this thread: http://www.jeepforum.com/forum/f11/headlights-2891137/
Thank-you.
Cannot stress the importance of the relay harness enough as the first thing to do.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #5 of 20 Old 07-15-2017, 08:14 AM
75SV1
Harness($20-$40), or Autopals($40-$50/bulbs). Then both. If you have the money, Hellas or Cibies. I haven't tested the harness with stock bulbs. So, I can't attest to that setup. I would rate the Autopals with stock wiring harness at 2X the light. Autopals with the harness 4X stock. I am also using the bulbs that came with the Autopals. So, they could be better with upgraded bulbs. I am judging this with near new stock halogens.
75SV1 is offline
post #6 of 20 Old 07-15-2017, 12:39 PM
bluejunior
bluejunior's Avatar
Harness! My lamps were getting 9v when the ****ty factory harness was under load. No headlamp does well under those circumstances.
Do that first, then grab some autopal housings and decent H4 bulbs if you want more.
Lifted, Locked, Stiffened
bluejunior is online now
post #7 of 20 Old 07-15-2017, 07:53 PM
mschi772
1997 XJ Cherokee
9v at your lights is about 30% voltage drop which translates into something like 70-90% decrease in light output. That's just scary to think about. Voltage drop in the factory lighting is insane ESPECIALLY after 20+ years of aging wires and connectors. Relay harness is SOOOO important.
mschi772 is offline
post #8 of 20 Old 07-15-2017, 08:14 PM
bluejunior
bluejunior's Avatar
I was shocked when I measured. It explained a lot. Wish I hadnt lost the comparison picture of passenger harness vs driver's factory wiring on stock spec sealed beams. It was eye opening.
post #9 of 20 Old 07-17-2017, 10:00 AM
COMTB
1989 XJ Cherokee
I don't want to thread hijack but it is related. How hard is it to completely replace the factory wiring instead of an add-on harness? Does the factory wiring not get used anymore with the new H4 harness (except or the switch)?
1989 XJ Build:
COMTB is online now
post #10 of 20 Old 07-17-2017, 10:24 AM
bluejunior
bluejunior's Avatar
WAY harder than makes any sense to do unless it's so badly damaged that you can't get a signal out to a relay harness. It's badly laid out, undergauged and between the dash and bay harnesses is wrapped up with about a billion other systems' wiring.
With an H4 add-on harness (bought or home made) the factory headlight circuit is still used, or at least the passenger side output is, but it only carries ~1 amp to activate the relays based on the factory dash/column switches.
post #11 of 20 Old 07-17-2017, 10:53 AM
COMTB
1989 XJ Cherokee
Thanks! Harness ordered. My Passenger side high beams don't work because they pinched the existing harness in between the radiator and the radiator frame (mount? whatever it's called). I need to remove the rad to see what happened and repair the wires.
Thanks for your info as usual @bluejunior
1989 XJ Build:
COMTB is online now
post #12 of 20 Old 07-17-2017, 12:32 PM
bluejunior
bluejunior's Avatar
No problem, and that shouldn't be too bad to fix. There'a a lot less in the harness that far forward, in fact if it split where I think it did it's just the three wire low/high/ground. take the battery out and you should have enough room to get an iron on it even in the bay. Worst case there's definitely enough room to slap in a patch wire and a couple crimp connectors, insulated ones last and there's no need for an ideal connection when you're just trying to trigger a relay.
post #13 of 20 Old 07-17-2017, 03:17 PM Thread Starter
lazaro99
thank you every one for theyre suggestions looks like im gonna do a little electrical work can anyone give me a link too a good wiring harness
post #14 of 20 Old 07-17-2017, 06:00 PM
bluejunior
bluejunior's Avatar
https://www.ebay.com/i/310881156715?...D1260372301250
That's the one I use. I had the more popular putco one, but had problems with the weird relays and connectors. The one above uses standard 5 pin relays that are easy to find and I haven't had any trouble with it. Plus it's about half the price!
post #15 of 20 Old 07-17-2017, 07:11 PM Thread Starter
lazaro99
thank you
