03-15-2011, 10:57 PM
#16
I have the NP242 and have the RE 3.5" SR kit with no transfer case drop. No crazy vibrations; just a tiny one at 30 MPH. I guess Jeeps are different?
03-16-2011, 08:23 AM
#17
You should paint the flares, and paint/remove side molding. Otherwise it looks good, can't wait to see it lifted.
White 2001 XJ: stock
White Jeep Club member #138
03-16-2011, 05:30 PM
#18
Read my mind  I am getting matching number paint, peeling off the side molding, and painting the whole thing. I know it will go off road but when its clean I want this puppy to shine. The top's clear is peeling and there are some imperfections as well in the paint (has been repainted). So I'm going to paint it the correct way
1997 Jeep Cherokee Sport 4 DR, C8.25, 4.0L, AW4
Build Thread: http://www.jeepforum.com/forum/f177/hartinarmz-1997-build-1170550/
1994 Ford Bronco Eddie Bauer, 5.8L, 2" lift, 33's
ASSIST-PROTECT-DEFEND
03-17-2011, 01:19 PM
#19
Just ordered the Mickey Thompson Sidebiters and am putting the lift on tomorrow!! Happy Drinking Day everyone!
03-19-2011, 03:33 AM
#20
Finished the lift about an hour ago and right when I started it up the idle jumped to 2K. the idle does not change. Any thoughts? Now I have yet to put on the drop bracket that came with the TC drop. Would this effect the idle? Thanks guys. Oh and pictures will follow...
03-19-2011, 09:34 AM
#21
Captain 400k
Disco the battery for a few minutes. This will reset the engine parameters in the PCM. Start the engine and let it run for a minute. If the engine doesn't idle properly after this, you likely need to clean or replace the IAC.
1998 Bright Platinum ZJ 5.9 Limited - 5.9l, 46RE, NV-242, D30/44a (Trac-Loc) w/3.73s - The DD
1999 White XJ Sport - 4.0l, AW4, NP-231, D30/8.25 w/3.55s - The Rig
My Photography
03-19-2011, 11:34 AM
#22
Drivin' me nuts...
Originally Posted by MCrock
Whats wrong with my 242??
Nothing! They're just jealous we can pull the lever for full-time in December, and leave it there until the spring thaw... with no damage to our u-joints!
'99 Classic: "Emma"
8.25 * NP242 * Auto trans * 3" OME HD lift * IPF lenses and H4s * Uniden PC78elite
JKS Discos and adjustable track bar * 31" BFG T/A KOs on 15x8 black Cragar soft 8s
Tom Wood's SYE and custom drive shaft * Custom evil shark mouth skid plate * Hingeless 2-way hood vents
Jeeps with Teeth #1
MN Jeeper #14
_____________________________________________
"When is the best time to do things? Who is the most important one? What is the right thing to do?"
"BORN TO WHEEL" PRODUCTS FOR SALE
********** More designs here**********
03-19-2011, 11:54 AM
#23
I'll try disconnecting the battery. HAha I'm a proud owner of a 242
03-19-2011, 10:56 PM
#24
Lift
Well the high idle was fixed by simply unplugging the battery. Thanks for the help csouers. Also got updated pictures!
Taking the clamps off of the leaf packs
Go figure, was going to break a bolt or two
Fuzzy picture but you can kind of see the rake
Little bit of frustration at this point
Knuckle busting. Gotta keep reminding myself I love the jeep...
LIFT COMPLETE
Had to put them on
So overall, had problems with the rear right shock mount (broken bolts), transfer case studs, and putting in the coils. But it was all worth it in the end. Now just waiting for the rims and tires
03-19-2011, 11:13 PM
#25
Oh and as far as vibes, minimal to none  Sounds like I'm sticking with the NP242
03-20-2011, 01:33 PM
#26
Get used to busted knuckles man. I got three different gashes today. Hell I punched myself in the face on accident working on the jeep one day. Build looks good so far man
2000 WJ LTD Shale Green metallic, stock for now
2007 Yeti AS-X, Avid Code 5's Rockshox Totem,
SOLD: 91 XJ
03-21-2011, 01:52 PM
#27
Well today I was driving the Jeep at a sustained speed of 55 MPH and I started to get a severe death wobble. Is this my sign that I need an SYE or is this a symptom of something else? I am very worried at this moment and need some reassurance!
03-21-2011, 03:22 PM
#28
Guess I should mention it has not been alligned yet... And I think I just answered my own question heh. Well rims came in today so tires and allignment will be done tomorrow. Pictures soon!
03-21-2011, 04:31 PM
#29
Yeah the rear upper sock bolts are tough, i had the exact same problem, cant wait to see it with the new tires and wheels
03-22-2011, 08:47 PM
#30
Rims and tires
Well finally put on the new rims and tires. Ended up going with 31x10.50 Yokohama Geolander A/Ts. Took a quick pic of it after I got it back home from the shop. I'll get better ones up tomorrow:
And the death wobble was from a bad steering stabilizer and no lock nut on the adjustable trac-bar. Woops
