HANMA LED Light Bars? - No Group Buy discussion permitted - Page 27 - JeepForum.com
post #391 of 660 Old 04-15-2013, 07:44 AM
TexasXJ97
1997 XJ Cherokee
Originally Posted by ultimo
Ordered a 50" with amber lens...ETA next week woohoo! Now I need to
1) find some security bolts for the light to bracket and bracket to bar
2) Get a bigger alternator
3) Fab a bracket to work with my WJ roofline.
4) Get a better power distribution block installed.
DOH!
I am just going to wire it to A/C to DC convertor so I dont have to wait to annoy the hell out of my neighbor. (whos dogs likes to pee on my BFs.)
You can upgrade your alternator if you feel like it, but that light bar won't pull more than 300W. A lot less than the light setup I have running with my stock alternator. It will perform better if you do the upgrade, but don't feel obligated.
TexasXJ97 is offline
post #392 of 660 Old 04-15-2013, 04:13 PM
roblaza
I got my 4 single led 10w spots and floods mounted and wired today. I have I wait for the darkness to come and I'll e aiming and taking more pics to update for those who are wondering why te output is on the small lights.
I did two seperated switches. One for the centre 2 lights (spot) and one for the outter 2 (floods)
roblaza is offline
post #393 of 660 Old 04-15-2013, 06:09 PM
Project1
Nice ..
Lets see some night shots
Project1 is offline
post #394 of 660 Old 04-15-2013, 06:29 PM
Silver_Sport
I like the switch location. Looks clean.
robbybobby: duh bro- momentium.....i have my own special technique- haul Mother F-ng balls at the hill till i am standing alone at the gawd danged top......
Silver_Sport is offline
post #395 of 660 Old 04-15-2013, 06:37 PM
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
i want to see the night shots, those look like they would work great as rock lights.
what was the pricing on them?
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline
post #396 of 660 Old 04-15-2013, 07:59 PM
roblaza
Originally Posted by Project1 View Post
Nice ..
Thanks, see below.
Thank you, I wanted them somewhere that was easy to reach and where is easier to reach than right under your hand??? LOL
For the night shots, see below. Pricing wasn't too bad at all. Cost was $19 EACH, but I ordered 10 of them total.
Well I went out tonight (just got back actually) from aiming the lights the way I wanted them and taking some pics. THESE PICTURES DO NOT DO THEM JUSTICE IN THE LEAST! I don't know how you mess around to set the camera settings properly, so they're somewhat bad pics, but you get the idea. They are the 10W Single Cree LED lights.
Lows only:
Lows and all 4:
Lows only:
Lows and floods only (I have them aimed to the sides to light up ditch areas, therefore majority of beam is cut off):
Lows and spots only:
Lows and all 4:
AGAIN, these pictures don't don't do them justice AT ALL. They really must be seen in person to truly appreciate the light that comes from the single LED 10W units.
roblaza is offline
post #397 of 660 Old 04-15-2013, 08:20 PM
mnewxcv
I contacted someone there and they said there is a minimum quantity, an entire carton? anyone else run into this? other than that, im ready to bite the bullet on a few things.
mnewxcv is offline
post #398 of 660 Old 04-15-2013, 08:37 PM
roblaza
There's no minimum, but the more you order the better pricing you get. Example: order 5 at $30 each or 10 at $20 each type thing
roblaza is offline
post #399 of 660 Old 04-15-2013, 09:13 PM
ultimo
sweet pictures, really bright! Just diverging a little since someone mentioned about rock lights, if you mount them underneath. How do you keep it clean?
Build Thread-- http://www.jeepforum.com/forum/f197/ultimos-build-1477712/
ultimo is offline
post #400 of 660 Old 04-15-2013, 09:14 PM
ultimo
I am replacing batteries much faster than I like due to short trips etc. I like the DC engineering ones but they are really ex, but good output in idle from 180amps to 270amps!
ultimo is offline
post #401 of 660 Old 04-15-2013, 09:39 PM
Project1
Really sweet for such small lights .. I'm stoked to get some
Project1 is offline
post #402 of 660 Old 04-16-2013, 12:19 AM
ultimo
How do you wire two lights to one cable? splice?
ultimo is offline
post #403 of 660 Old 04-16-2013, 12:50 AM
Project1
You just need to check the amps and use a relay .. its really not to hard. Its probably a 30amp relay but I would check to be sure, that's just a total guess.
Project1 is offline
post #404 of 660 Old 04-16-2013, 02:39 AM
ultimo
what about the power cable? Sorry I am newbie with electric connections...just shorted the flasher fuse 3 times before I got it right
How do you wire the power cable to go to two lights on one cable?
ultimo is offline
post #405 of 660 Old 04-16-2013, 02:44 AM
Project1
just google search how to hook up a relay ..
The frist time I hooked one up it took me a while and I had to read the thing like 3 times before I got it, but once you get it ... its really easy. Then you can use one switch too, witch is nice.
Project1 is offline
