hand bulit 88xj...no bolt ons. - Page 3 - JeepForum.com
post #31 of 62 Old 07-25-2013, 09:30 AM
XJ Jay
im gonna steel your idea of tying the cage to the exo, its effen brilliant.
HISWhite 99 XJ Sport
5" RC/ProComp lift, Serious long arms, 33" Cooper STTs, Soft 8s, 4.56s, Aussie locked D30, LSD 8.25,discos, armoured blah blah blah, HP44/9" coming soon
HERSBlack 08 JK Unlimited X, Teraflex 1.5" leveling kit, Rubi coils 35" TSRs and 5.13s
XJ Jay is offline
post #32 of 62 Old 07-25-2013, 09:36 AM
ibjeepin95
It's called a hybrid cage. People have only been building them like that for forever now...
ibjeepin95 is offline
post #33 of 62 Old 07-25-2013, 09:44 AM
DNFJ
This thing is awesome, amazing work man.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #34 of 62 Old 07-25-2013, 10:28 AM
TheRealKTrain
JK Wrangler
LMFAO, exactly my thoughts when I read that too
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." Aristotle
Μολὼν λαβέ
TheRealKTrain is offline
post #35 of 62 Old 07-25-2013, 11:55 AM
Mikes96XJ88FSB
Very cool build!
-Mike- 96 XJ Country: 4.0 HO, Auto, 3.55s, D30/8.25, 30X9.50s, Armored, Mopar Header, Glasspack, Custom Stereo, Roof Rack, 3in RC & 2in Blocks.
88 Bronco XLT: #'s Matching with 58k miles, Built Windsor making north of 440hp, C6, 4.10s, 31X10.50s. Factory Quad shock.
Mikes96XJ88FSB is offline
post #36 of 62 Old 07-25-2013, 12:47 PM
ibjeepin95
By the way, very cool build. I dig the cage work.
post #37 of 62 Old 07-26-2013, 02:21 PM Thread Starter
domaas
made some tube doors awhile back as well
cut and notched ready for welding.
welded up.
matched for both sides.
added some rotary latches, 2 stage locking.
doors fitted up.
domaas is offline
post #38 of 62 Old 07-26-2013, 02:35 PM Thread Starter
domaas
shackle relocation brackets
needed some shackle relocation brackets...so of course i had to build them
started with some cold plate, laid out all the bolt holes and drilled them out.
welded on the side plates.
thought i had some pics of the nut stirp inside the body..but i dont. its 3/8 2" wide plate, with 4 1/2 " grade 8 nuts welded to it. there is also a 2x2 .250 wall tube that fits into the stock shackle bolt location. once again, sorry, no pics of that either.
plates installed, looks like a good shackle angle, and adjustable.
domaas is offline
post #39 of 62 Old 07-26-2013, 02:47 PM Thread Starter
domaas
cooling system upgrade?
when i bought the rig, the stock fan clutch was junk, and the fan shroud was missing, electric e fan had cracked mounts. so why replace, when you can upgrade right?
decided on a e fan upgrade all around.
started with some sheet aluminum.
marked out the fan locations, and cut them out.
made a simple jig for the plasma cutter.
ended up with this.
test fitted the fans befor i put it in the brake for the edges.
welded up the edges.
then tacked in some seperator plates to prevent "cross flow" of the fans.
test fitted the fans on the radiator. the original closed system had cracks in the tanks, so i upgrade to a newer open style radiator.
installed new radiator
added a auto fan relay with a late model t stat housing holding the thermo sensors, 2 fans click on auto and off auto, third fan sits in front of the trans cooler, and is manually controlled.
domaas is offline
post #40 of 62 Old 07-26-2013, 03:04 PM
Spokes
Looks good!
Red 00 XJ lifted
Build -->
Blue 00 XJ Hella stock
"Lima bean" 91 XJ 5spd
Spokes is offline
post #41 of 62 Old 07-28-2013, 10:10 AM
Camfam07
wows this is a great build, love everything your doing to it!
Camfam07 is offline
post #42 of 62 Old 07-29-2013, 12:16 AM Thread Starter
domaas
Thanks bud,it's been a fun project.
domaas is offline
post #43 of 62 Old 07-29-2013, 10:29 AM
husker88jeep
1988 XJ Cherokee
where did you find those red fans?
husker88jeep is offline
post #44 of 62 Old 07-29-2013, 11:28 AM Thread Starter
domaas
They are just cheap fans from Ebay,have no idea on the reliability of the fans,but there is 3 of them, and it's no daily driver. With that being said,I will see how well they hold up. I have used the fan controller in the past on my old,hot rod..held up for years till I sold it.
domaas is offline
post #45 of 62 Old 08-01-2013, 12:36 PM Thread Starter
domaas
rebuilt the transfer case, te syncro rings were trashed, as well as the shift coller bushing. replaced all with new parts from quadratech.
no pics of the short shaft sye(you all have seen hundereds of them, but got a great deal on a built rar shaft from a local vendor.
domaas is offline
