Quantcast Haleyrz XJ Build - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Non-Technical Forum > Haleyrz XJ Build
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 10-06-2009, 12:56 AM   #91
Haleyrz
1997 XJ Cherokee
I'm not sure if there is room to run a true dual. Well......anything is possible, but it may take some fab from a muffler shop which could run you alot.
1997 Jeep Cherokee, 4.0L, 30x9.50 Maxxis Bighorns, d-window wheels, cut fenders, chopped bumpers, flex-a-lite, flowmaster super 44
2003 Grand Cherokee Overland, 4.7L HO V8, 6000K HID's - SOLD IT
1996 Grand Cherokee Laredo, 5.2L V8, 3" Kolak exhaust w/ flowmaster 50 and magnaflow cat, K&N FIPK, 4300K HID's - SOLD IT
My build thread
http://www.myspace.com/HaleyChicoine
http://www.facebook.com/home.php#/profile.php?id=1646857227&ref=profile
Haleyrz is offline   Reply With Quote
Old 10-06-2009, 01:12 AM   #92
Luke94XJ
1994 XJ Cherokee
I'm sure there's a setup for the wj, that was what he was talking about right?
Luke94XJ is online now   Reply With Quote
Old 10-06-2009, 01:29 AM   #93
Kevin108
Back from the dead @ 167k
Kevin108's Avatar
Originally Posted by Haleyrz View Post
Whoa...ok. First off, headers have benefits when put on full systems, just like you only see benefits with CAI's when you have a full system on. I know this.
Very, very true. Free flowing exhaust plus more air and more gas in will definitely make a difference together. Apart they are negligible.
Me, I'm a very mild wheeler, and this is my DD, my only vehicle, so I see performance, efficiency and economy as more important than lifts and recovery. I'd love a huge *** jeep just like the next person....but I'd also like to keep things realistic and practical.
My goals as well, which is a big part of why I am so interested in your build.
It took me a while, but I finally figured it out: catastrophic failure and
the subsequent repairs is the Jeep thing they're always talking about.
Kevin108.com | My 2000 XJ Build | Hampton Roads Jeep Club
How to reindex the camshaft position sensor on an 00-01 XJ
Tips on trimming 97+ XJ bumper end caps and lower facia
Kevin108 is offline   Reply With Quote
Old 10-06-2009, 02:59 AM   #94
Deezelweazel
Go with the banks header, even it is more expensive. Banks has a good reputation for quality. He tested his stuff seriously. A good designed header is a very good basic for further perfomance mods.
We usually wrap the header with heat shielding wrap to keep the heat in the exhaust and to improve flow of the hot exhaust gas. It helps to keep up speed of the exhaust gas.
The intake won't be that hot as usually and cooler air is, as we know denser. You will get the most gain with a bored out throttle body. It's a relative cheap mod, but remarkable.
But keep away from those sport filters. German military has tested them for truck use, because they wanted to save money with that reusable thing. But it turned out, that those filters let pass a lot of contaminants. Too much of them!
So stick with the stock box and change filters often and you will be fine.
You can reduce friction by using a good quality oil.
But it is useles to save gas, if you run those big tires on a daily basis. Friction caused by this tire size and thread is the cause for low mpg.
Over here we go with street tires and only change them when we go Off-road. It's to expensive.
If it is your daily rig, you will gain a good mpg with regular tires.
Just my
Michael
Go hard, go Diesel! - Turbocooled and Intercharged...
Deezelweazel is offline   Reply With Quote
Old 10-06-2009, 05:29 PM   #95
Haleyrz
1997 XJ Cherokee
Haha, thanks Mike. Yeah, those CAI's do let a lot though. I mean people complain about the K&N's gumming up the TB, or letting too much crap through. True they can do that. My two cents on that is too much oil, gummy TB, too little and your letting a lot in. I will someday get an Amsoil cone filter. Awesome flow, but filters just as good as paper. Reason I have my filter like it is, is that i bought it that way, and am too lazy and cheap to go pull a stock box out of the JY. I dont really want to go back to paper filters. I like the noise my new bigger spectre filter gives the engine at WOT . True on the MPG gains vs. bigger tires. But upon regearing you bring your jeep back to similar stock mpg....so you'll still see it. I like synthetic oils and such, not cuz the mpg claims (which doesn't matter much in a jeep), but i like to give my engines the...."gormet treatment" if you will . Anyways, enough of me babling.
My build thread
Old 10-06-2009, 09:06 PM   #96
CHAMPTEK
hahah i like to give my engine the "gourmet treatment" aswell hopefully well get paid back by long engine life lol
CHAMPTEK is offline   Reply With Quote
Old 10-08-2009, 12:08 PM   #97
Deezelweazel
I like Syns because the engine is soooo clean inside. And to be honest, it's just the "feel" to have done everything possible to pamper the engine
I have built together with a friend, who works in that business, my own exhaust- it's just a straight 2.5" stainless mandrel bent tube without any muffler. It's a turbo- so it's not too loud.
Old 10-08-2009, 05:29 PM   #98
Haleyrz
1997 XJ Cherokee
So I am currently sitting in the tire shop watching a show on the hippies in the 60's waiting for my bighorns to get mounted and front end popping noises to be diagnosed!!
My build thread
Old 10-08-2009, 10:15 PM   #99
Haleyrz
1997 XJ Cherokee
just for fun, a picture next to my boyfriend's TJ when we met for lunch:
Annnnd, the XJ got new shoes as said above! Looks pretty good. They measure exactly 29" when mounted. They are taller than the BF's 30" toyo a/t's, and almost as tall as the roommates 31" toyo a/t's. They already rub on the inner fender wells when flexing like coming out of a parking lot....so the 31's would have rubbed pretty bad, so I'm happy with them!!
And here the XJ is looking at an explosion
My build thread
Old 10-08-2009, 10:47 PM   #100
nwfjarhead
Semper Fi
nwfjarhead's Avatar
looks awesome!!!
www.panhandleoffroadkrew.com
nwfjarhead is offline   Reply With Quote
Old 10-08-2009, 10:48 PM   #101
daufuskieraised
Looks good Haley! I love that green and the fenders look like they were cut well!
1996 ZJ Laredo
1.75"BB, Monroe Shocks
Cheap Radioshack CB radio
Magnet antenna
daufuskieraised is offline   Reply With Quote
Old 10-08-2009, 11:31 PM   #102
Haleyrz
1997 XJ Cherokee
Thanks guys! I can't take credit for cutting the fenders, but the previous owner did do a good on the chop job! Just didn't take very good care of the poor thing
My build thread
Old 10-08-2009, 11:33 PM   #103
96_XJ_Sport
love that last pic
Just Empties Every Pocket - 96 XJ Sport,- 4.0 H.O. - 235/75/15 General Grabber AT2's - Black D Windows - Hella 500FF Driving Lights - RC 4.5 X-series
ΜΟΛΩΝ ΛΑΒΕ
96_XJ_Sport is offline   Reply With Quote
Old 10-08-2009, 11:54 PM   #104
nwfjarhead
Semper Fi
nwfjarhead's Avatar
hey speakin of fenders do ya think you could get a couple pics of the inner fender well, Gettin ready to do mine and trying to see the different ways it has been done.
Old 10-08-2009, 11:56 PM   #105
Haleyrz
1997 XJ Cherokee
Sure thing man, I'll do that tomorrow after work. I get off at 3pm pacific time, lol. Expect them around 3:30.
My build thread
Glock Forum
