Hack n' Tap SYE Drill Jig - JeepForum.com
post #1 of 14 Old 08-22-2013, 06:12 PM Thread Starter
Ekul310
Anyone have a jig to drill the hole in the output shaft for a hack n tap sye they're looking to get rid of for cheap? I can't justify spending $30 for it new. Thanks!
'99 XJ 4.0 AW4/242
Fiscal responsibility, legalization of Marijuana, small gov't & 2nd amendment.
Ekul310 is offline
post #2 of 14 Old 08-22-2013, 08:57 PM
Metro55
No need for the jig... Cut the output shaft then slide the yoke on... Drill in the center of the center hole of the yoke.... There you go, just saved you the worst $30 you would have spent
.,,_____,====,
//__l_l_,\____\,_____
l_,--\_l__l_/--|[]llllll[]|
,()_),,,,,,()_)--o-)_) Caged
Metro55 is offline
post #3 of 14 Old 08-22-2013, 09:41 PM Thread Starter
Ekul310
I actually never thought of using the yoke. Thanks so much!
'99 XJ 4.0 AW4/242
Ekul310 is offline
post #4 of 14 Old 08-22-2013, 10:19 PM
Metro55
No problem bud. Work smarter not harder
.,,_____,====,
Metro55 is offline
post #5 of 14 Old 08-22-2013, 11:03 PM
XJmike0122
Good tip man.
XJmike0122 is offline
post #6 of 14 Old 08-23-2013, 08:15 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Good words to live by. You in the fire service?
I gotta remember that trick should I decide to go the hackntap route.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #7 of 14 Old 08-23-2013, 01:20 PM
98muddyjeep
rockin lil red wagon
98muddyjeep's Avatar
How did you cut the shaft? Did you put it in gear and hold the cutting wheel still and let the jeep do the work?
ah,beer the cause of and cure to all of lifes problems ...Homer J Simpson... I am the guy in the red jeep!
98muddyjeep is offline
post #8 of 14 Old 08-23-2013, 01:21 PM
Metro55
Exactly... make sure you're cutting against whatever the direction the shaft is spinning. It works GREAT with a clean cut!
.,,_____,====,
Metro55 is offline
post #9 of 14 Old 08-23-2013, 01:28 PM
rallybro
Put it in reverse so that it spins the opposite direction of the grinder. Cutting goes quick and easy. Aaand it leaves a tiny point in the exact middle of the shaft.
rallybro is offline
post #10 of 14 Old 08-23-2013, 06:10 PM
Modstock
I got one cause its cheap insurance and it gets a straighter hole drilled .
Modstock is offline
post #11 of 14 Old 08-23-2013, 07:18 PM Thread Starter
Ekul310
I figured since I started this thread, and couldn't fin a jeeper who has used it, have any of you used the dirt bound offroad HnT with the yoke instead of the flange, if so, what do you think about it? I'm thinking of going that route because I have a 98 and it would only be 99 bucks for it
'99 XJ 4.0 AW4/242
Ekul310 is offline
post #12 of 14 Old 08-23-2013, 09:57 PM
Modstock
Check out my build thread .
Modstock is offline
post #13 of 14 Old 08-24-2013, 12:22 AM
XJmike0122
Now I'm thinking I'm going to be going this route also. Thanks
post #14 of 14 Old 08-24-2013, 02:02 AM Thread Starter
Ekul310
Thanks. You're one of the few using it. It seems like a good kit and great price. I think I'll be going this route
'99 XJ 4.0 AW4/242
Ekul310 is offline
drill , hack and tap
