h3 wattage fog lights - JeepForum.com
post #1 of 5 Old 08-16-2008, 10:41 PM Thread Starter
RavenCorax
1988 XJ Cherokee
my light burned out in my fog light right now their street legal 7 inch round fog lights 55 watt
been looking up lights on ebay,quadratec and autozone. 55 will keep it street legal 100 watters are the same price 130's are like a buck more.
the wiring is sound so is the relay the only thing im worried about is the heat its a glass lense and has some plastic housing crap.
piaa is like 55 watt equivilant pricy stuff
some ebay junk is blue hid plasma crap or yellow
any ideas?
2 door cherokee
I wave
RavenCorax is offline
post #2 of 5 Old 08-16-2008, 10:49 PM
XJLI
XJLI's Avatar
1993 XJ Cherokee
what kind of lamps? if the stock bulb is a 55w i doubt the wire is thick enough to hold a higher wattage, and if the reflector is crappy you wont get a good beam out of it.
Factory Four Link
XJLI is offline
post #3 of 5 Old 08-17-2008, 05:11 PM Thread Starter
RavenCorax
1988 XJ Cherokee
the wiring is part of the bulb on mine and the beam pattern is just fine kinda longrange but really wide
2 door cherokee
I wave
post #4 of 5 Old 08-20-2008, 07:22 AM
XJLI
XJLI's Avatar
1993 XJ Cherokee
that makes 0 sense. all H3 bulbs have a wire attached to them. i meant the actual wiring to the battery, relay, switch, etc.
if its some off-brand light kit, anything more than a 55 wont even get you a nicer light output, itll just be brighter with a crappy beam. and itll probably burn out the wiring.
Factory Four Link
XJLI is offline
post #5 of 5 Old 08-20-2008, 06:57 PM Thread Starter
RavenCorax
1988 XJ Cherokee
i did all the wiring myself its more then adequate. 4 gauge to the auxilary fuse box and i believe 12 gauge to each light. a nice relay about 8 inches from the fuse box. the grounds have been sanded and gooped with silicone dielectric.
the only thing im wondering is how much more heat the higher wattage bulbs will make? why would higher wattage bulbs mess with the beam pattern?
2 door cherokee
I wave
OEM fog lights....wattage? xjinga XJ Cherokee Technical Forum 2 12-15-2006 01:12 PM
IPF headlights and over-wattage bulbs ibran XJ Cherokee Technical Forum 9 12-31-2004 05:30 PM
High wattage H4 bulbs tibim XJ Cherokee Technical Forum 16 12-06-2004 05:00 PM
H4 wattage bradley9101 XJ Cherokee Technical Forum 7 11-23-2004 04:19 PM
Factory Stereo wattage Todd Brown XJ Cherokee Technical Forum 3 09-15-2004 09:16 AM
