Good deal and a couple of tech questions - JeepForum.com
post #1 of 1 Old 07-27-2008, 10:14 PM Thread Starter
Deereman12
I'm looking at buying a 95 Cherokee as a weekend run around vehicle. I found one with 143,000 miles on it 4wd. Owner wants $1800 but will probably come down to $1500. Owner informed me that 4wd doesn't work but didnt' know why. I inspected the vehicle and found the front driveshaft is missing. Also, I'm not familiar with transfer case operations but when I shifted the case into hi or lo I could still spin the front shaft yoke. The case is busted correct? I figured if it's shifted to the tranny and the vehicle isn't moving it shouldn't turn.
Also the oil pressure gauge isn't working. I told the owner I wouldn't buy it until I check the actual pressure. What size fitting do I need? 1/8 pipe thread?
What's a good source and price on the driveshaft and tranfer case? Sorry for all the questions and go easy on me because I'm a Newbie!
Deereman12 is offline
Couple of Tech Articles with Broken Links rc76 XJ/MJ Cherokee Non-Technical Forum 0 06-08-2009 03:24 PM
Tons of good Tech info lathan888 XJ Cherokee Technical Forum 0 03-12-2009 07:11 PM
two tech questions polock XJ Cherokee Technical Forum 8 04-25-2008 02:14 PM
Couple of tech questions LiBMXr1390 XJ Cherokee Technical Forum 2 02-28-2008 10:57 PM
Couple Low Tech Mods and Some NEW TIRES FINALLY!! J_Mayle XJ Cherokee Technical Forum 10 08-04-2007 12:14 AM
