Going doorless: yay or nay? - Page 4 - JeepForum.com
post #46 of 84 Old 04-25-2013, 02:40 PM
Joshharris98xj
Originally Posted by DNFJ
Re-read my comment. I said on a DD. If it's a trail rig who cares, but if it's a DD you have the possibility of getting into a far more serious accident, in which case the doors are important.
So wranglers are dumb also?
Joshharris98xj is offline
post #47 of 84 Old 04-25-2013, 02:41 PM
Rockdrummer93
Originally Posted by Joshharris98xj View Post
They come off just as easy if you "skip" that hole on the body and just go around the kick panel. All you do is weld the pins in place so when you take them off you pull and lift. Pretty simple if you ask me.
I don't understand what your saying.. I did modify mine to just pull the doors off. What do you mean by going around the kick panel?
2014 Cherokee Of The YEAR
Rockdrummer93 is offline
post #48 of 84 Old 04-25-2013, 02:44 PM
Joshharris98xj
Don't go through the "body hole" skip it. Leave the kick panel off, clean up wiring if your picky like that, and that way you don't have to feed them through.
post #49 of 84 Old 04-25-2013, 04:54 PM
Rockdrummer93
You are going to have to post a pic.. I still don't follow.
post #50 of 84 Old 04-25-2013, 05:46 PM
Joshharris98xj
Ignore how messy the wiring is I haven't gotten around to cleaning it up. I plan on ditching the boot and trimming the kick panel to put it back in so I can still access the wiring
post #51 of 84 Old 04-25-2013, 05:47 PM
Rockdrummer93
It doesn't pinch the wires?
post #52 of 84 Old 04-25-2013, 05:49 PM
Joshharris98xj
No that's weather stripping it doesent hurt them at all infact feeding them through the body so much was cutting in to them so I did this.
post #53 of 84 Old 04-26-2013, 05:58 AM
DNFJ
Actually yes.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #54 of 84 Old 04-27-2013, 03:51 PM
Project1
HELL YES to Doorless
Project1 is offline
post #55 of 84 Old 04-29-2013, 01:00 PM
dcorn
Originally Posted by DNFJ View Post
Glad I don't have long arms. Good try, idiot.
Taking doors off a DD is stupid, even stupider considering it's a unibody.
Sorry, a 6.5" short-arm lift is much better
And I'm pretty sure people with DD's don't take the doors off and throw them in the garbage. Half of this thread is now how to make them reattach properly. You've said your opinion, and really don't have much more to add to the thread except refuting every person that doesn't agree with you.
My advice is don't half-*** the door removal mod because you will eventually f*ck up the doors like I did. 5/16" pins don't work if you want to remove the doors more than once, unless you like replacing those little bushings every single time. Bushings aren't necessary, but properly drilled holes and lined up hinges are. 3 out of 4 doors on my Jeep are easily removable and close exactly like factory with zero sagging over a couple years (now that I fixed them with 3/8" pins). The last door is an exception because I'm pretty sure I tweaked the a-pillar and nothing can be done to fix it.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #56 of 84 Old 04-29-2013, 06:47 PM
Project1
I have been doorless 24/7 for 3+ years now and LOVE IT!!!
Project1 is offline
post #57 of 84 Old 04-30-2013, 05:25 PM
mountainjock
1988 XJ Cherokee
I thought about going doorless, but then I pictured my wife in the passenger seat at 10,000 feet on some pass in a rain storm and thought better of it. I vote NAY.
COLORADO JEEP CLUB MEMBER # 312
88 XJ 3" Pro comp lift 31/10.50
231 TC
4.0 I6
mountainjock is offline
post #58 of 84 Old 05-01-2013, 10:25 AM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
Plan ahead and look at weather forecasts? Bring a rain jacket? That's a lame excuse to stop you from even trying it. That will rarely happen.
1990JEEPXJ is offline
post #59 of 84 Old 05-01-2013, 10:38 AM
ibjeepin95
Wait, WTF? I wasn't going to post in this thread, but it is so full of retarded that I can't help myself. First, to stay on topic, its OK to take your doors off. On a DD, it's going to suck if you have a 98+ and it's your DD because they will sag. I take my doors off for the sole reason that it is much more easier to see what is going on while I am wheeling. As far as the unibody twisting, taco-ing, whatever you think might happen....are you serious? This has been covered in a billionty other threads on nearly every other forum and there are enough people wheeling the ***** out of stuff to show that the doors have little effect on the structure of the unibody. However, they will help in a crash, but those are T totally difference forces. I and my friends have wheeled and jumped a few XJ's hard with no doors or frame stiffeners, or anything to beef up the unibody by any means and if they are not straight, it's not noticeable.
As far as the IRO long arms, if you can't tell why they suck on your own, then I am sorry. It's far from what I would consider a true "3 link" and there is a reason other companies out there don't run a stock sized bolt on the ONLY upper link and that dumb caster adjustment bracket. Yes, I have experience with the kit. I have a friend that has one on his rig. It scares the hell out of me. I can't even imagine why people won't throw an extra $100 bucks at a quality, TRUE 3 link that runs a larger bolt on the upper link like the Rock Krawler kit. It is very close in comparison to the Poly Performance kit. Notice how I said close. Poly still has a better kit, but I'd run Rock Krawler on a budget.
ibjeepin95 is offline
post #60 of 84 Old 05-01-2013, 10:47 AM Thread Starter
YJeeper89
Thank You!
1989 Wrangler Islander: SOLD
1999 Cherokee Sport: SOLD
1996 Cherokee Country project
YJeeper89 is offline
