Getting Rid of the Startup Beeps - JeepForum.com
post #1 of 10 Old 02-08-2009, 11:33 AM Thread Starter
ksander
I was wondering if anyone knew how to make it so it doesn't beep five or so times everytime you start it up. Couldn't find anything through search.
RE 3.5 Super-flex, RE Monotube Shocks, 31 MTR's on Moabs, RE HnT and CV driveshaft.
ksander is offline
post #2 of 10 Old 02-08-2009, 05:23 PM
jeepkid03
Winning
jeepkid03's Avatar
put your seatbelt on before you start it? Thats what I do... in a more serious sense I believe there is a way to disable it as I've heard of people getting rid of the annoying buzzer on older XJs. My friend is borrowing my haynes repair manual because his '89 jeep is having some electrical issues, so I can't look it up but maybe you could do a google search and find the wiring harness for it.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #3 of 10 Old 02-08-2009, 06:05 PM
philjeeper
1987 XJ Cherokee
on my 87 there was a little black box right by the steering column with one plug going into it. I just unplugged it and no more annoying buzz.. to make sure you unplugging the right thing just make it go off and listen to where it is coming from
philjeeper is offline
post #4 of 10 Old 02-08-2009, 06:29 PM Thread Starter
ksander
I don't understand the seatbealt comment, I'm talking about the five beeps that it makes when you turn the key in the ignition.
ksander is offline
post #5 of 10 Old 02-08-2009, 07:11 PM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
The beeping is reminding you to buckle up. Buckle before you put the key in and crank it, and it wont beep at all.
88XJSport is offline
post #6 of 10 Old 02-08-2009, 08:19 PM
jeepkid03
Winning
jeepkid03's Avatar
Does it beep with the seatbelt buckled? That means its not sensing you have your belt on.
-Josh
Build Thread:
post #7 of 10 Old 02-08-2009, 08:37 PM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
post #8 of 10 Old 02-08-2009, 08:49 PM
bmyohn
Youngin'
bmyohn's Avatar
i like to make it a race to see if i can get my belt on before the beeps stop. works on my little brother to get him to wear his seatbelt too lol
2014 Jeep Wrangler Sport S
3.6L V6 - Manual
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford HP D60 l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l39.5" IROKsl 17x9" Pro Comp 98sl High Clearance Shock Mounts [COLOR="red"] l Hidden Hitch l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l Sterling 10.25 *FULL WIDTHS* l JKS Mini Skids and Sway Bar Brackets l 7/8" Heim Joint High Steer
bmyohn is offline
post #9 of 10 Old 02-09-2009, 08:10 AM
jeepkid03
Winning
jeepkid03's Avatar
Thats what I meant...as in does it beep when he has his belt already buckled which means its not realizing he already has his seatbelt on.
-Josh
Build Thread:
post #10 of 10 Old 02-09-2009, 01:39 PM Thread Starter
ksander
Yeah, I didn't realize the beeping was for the seatbealt. It does go off if the belt is buckled first. But I would still like to know how and if you can turn it off.
ksander is offline
Driving after startup cherokee99spt XJ Cherokee Technical Forum 4 07-19-2006 10:33 AM
Squeal on startup with A/C on RWB214 XJ Cherokee Technical Forum 13 07-04-2006 02:11 PM
Hesitant startup Jmila1901 XJ Cherokee Technical Forum 2 05-08-2006 04:16 AM
Lights on startup??? Tweaker_G XJ Cherokee Technical Forum 2 11-21-2005 04:46 PM
3K RPM at startup... Help! Sterling90XJ XJ Cherokee Technical Forum 7 04-11-2004 02:48 AM
