gather around good friends.. - JeepForum.com
post #1 of 25 Old 03-17-2011, 06:27 PM Thread Starter
98muddyjeep
rockin lil red wagon
98muddyjeep's Avatar
I have some bad news to share,as of yesterday my jeep was diagnosed with a rod knock.While shes being brave and trying to keep upbeat I know shes hurt bad. I am hoping this weekend weather permitting I will be able to do some exploratory surgery and see how bad things are.Depending on my findings I may just get the crank ground and polished and go with oversized bearings,I cant hurt things anymore so well see what happens.If that fails I will be looking for a new motor,i have to much time invested in her to just let her go so wish me luck.
ah,beer the cause of and cure to all of lifes problems ...Homer J Simpson... I am the guy in the red jeep!
98muddyjeep is offline
post #2 of 25 Old 03-17-2011, 06:40 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Good luck and hope it works out for you.
xjfever is offline
post #3 of 25 Old 03-17-2011, 06:54 PM
jeeptorino68
1992 XJ Cherokee
stroker...
Kyle
92 XJ 4.0 HO,AW4, NP242, 30" BFG AT, 1.75 spacer and ZJ coils, double cherokee leaf pack and 2 inch rough country shackles, 2.5 inch dnynomax exhaust, magnaflow cat, front hooks & rear hitch, gas skid, front skid, warn t-case skid, 99+ intake, bored TB
02 KJ Limited, 255 70 16s, front skid, LS/373 gears
jeeptorino68 is offline
post #4 of 25 Old 03-17-2011, 07:03 PM Thread Starter
98muddyjeep
yea after 9 years and 138,000 miles(she already had 60,000 on her when i got her)she finally went,Im just kinda sad she didnt see 200,000 miles, I havent done anything to the motor other than oil changes, tune ups, belts a waterpump and alternator.I though about a stroker but with gas threatning to hit 5 bucks a gallon im not looking forward to using premium,but well see that could change real fast.
post #5 of 25 Old 03-17-2011, 07:04 PM
warbuk
that sux, check on a long block assembly.
95' ZJ grand cherokee
91' XJ cherokee
warbuk is offline
post #6 of 25 Old 03-17-2011, 07:42 PM
meadz
I feel your pain my motor just blew last week..
meadz is offline
post #7 of 25 Old 03-17-2011, 07:46 PM
Crazystang89
1995 XJ Cherokee
Keep the compression down to around 9.0:1 or lower and using regular pump gas wouldn't be a problem. Also, gas mileage tends to increase slightly in stroker engines due to more low end torque. If you are gonna rebuild it anyway, you might as well.
1995 Cherokee Country 4x4
RC 3 inch, 30x9.50 MTs, DD
Originally Posted by BeepBeepGoJeep View Post
LOL heres how I see it....arguing over the internet is like being in the special olympics....even if you win you're still retarded.
Crazystang89 is offline
post #8 of 25 Old 03-17-2011, 07:54 PM
Brookhart63
Drop a hemi in it sorry about your engine. im pretty sure gas mileage should go up like posted above. The less load a engine has the better the mileage. example: girlfriends dad just bought a 1989 S10 with a 350 dropped in and it gets 27mpg. But the bracket only allow less than 1/3 throttle so it keeps the tires. Nothing is wrong with strokin it!
Brookhart63 is offline
post #9 of 25 Old 03-17-2011, 10:06 PM
Aero
poor thing.. I got mine last month with 170k, and seeing all these makes me think I'm gonna' be crying sometime soon.
Aero is offline
post #10 of 25 Old 03-18-2011, 04:48 AM
husker88jeep
1988 XJ Cherokee
i put a crate motor in mine last fall... cost me about 1500.00 but it was cheaper than buying a new XJ
husker88jeep is offline
post #11 of 25 Old 03-18-2011, 05:52 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
For sure rod knock? What's the oil pressure?Is it auto trans? If so, check the flexplate to torque converter bolts. They back out a mimmick a rod knock.
cruiser54 is offline
post #12 of 25 Old 03-19-2011, 10:14 AM Thread Starter
98muddyjeep
im pretty sure its a rod knock wel maybe a spun bearing, I had to limp her home and if i worked the gas just right the noise would go away and come back when i let off the gas.Oil pressure has been great at just a hair above 40 psi while moving and 10-15 at idle.I am going out in a bit to start looking around,I would love to rebuild it as a stroker but money is a bit tight right now but i do have future plans for a stroker motor but this is my DD and i have no plans on getting rid of her I am almost done building her so way to much time and money invested to stop now.
post #13 of 25 Old 03-19-2011, 10:24 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
If the rattle is when OFF the gas, it's way more likely to be the flexplate bolts. Bearing knocks are under load, not coast, and are accompanied by low oil pressure. If I were you, I would enthusiasticly be crawling under there to check the bolts on the flexplate to torque converter. If this is the problem, you must send me a gift certificate for one six-pack of Guinness Extra Stout.
Any questions on checking the bolts, post up. We'll help you through it..
post #14 of 25 Old 03-19-2011, 04:44 PM Thread Starter
98muddyjeep
well I just pulled the inspection cover and its not the flywheel bolts they were all tight,its also not a rod knock but I did find the skirt of piston # 2 in the oil pan.I can see the cylinder and it looks good, no scores just missing a chunck of the side I can see the rings but like i said the cylinder wall is ok not to sure what to do now theres not to many motors for sale in the area right now and cash is low so i may look into a new piston any thoughts on this idea? Thanks for all your suggestions.
post #15 of 25 Old 03-19-2011, 08:22 PM Thread Starter
98muddyjeep
after doing some looking I know its cheaping out but I found I can get a piston for 41 dollarsso what do you guys think good idea or giant fail?Keep in mind moneys tight right now and its only a temp fix for a few months.
buildup of friends xj jeepbro's XJ Cherokee Technical Forum 11 05-01-2009 08:00 PM
my friends xj and his problem white_elephant XJ Cherokee Technical Forum 4 01-22-2008 12:58 AM
Hey Friends CherokeeXJ1996 XJ Cherokee Technical Forum 9 08-27-2006 06:23 AM
my friends xj is a p.o.s! rsoffar XJ Cherokee Technical Forum 9 06-22-2005 06:59 PM
Need immediate help friends!!! tozier9 XJ Cherokee Technical Forum 6 02-08-2005 09:17 PM
