gas tank skid - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > gas tank skid
Poison Spyder JK LED Taillight & Wiring Harness KitsPoison Spyder JK Crusher CornersPANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi
Unread 07-09-2015, 11:17 AM   #1
meangreeny
gas tank skid
I have a 1999 factory gas tank skid pan ,will it work on my 1996 model or should I hand it over to my buddy with the 98 cherokee
meangreeny is offline   Reply With Quote Quick reply to this message
Unread 07-09-2015, 11:30 AM   #2
bluejunior
As far as I know, gas tank skids are 84-01 compatible.
Lifted, Locked, Stiffened
Build
bluejunior is offline   Reply With Quote Quick reply to this message
Unread 07-09-2015, 11:34 AM   #3
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
XJ gas tank skids fit either 84-96 or 97-01. You can modify them to fit, but it would be easier to just find the one you need, or trade with somebody in the same situation.
Total US debt has increased by 70% under Obama, from $10.625 trillion on January 21, 2009 to $18.005 trillion January 1, 2015.
Progressive Liberalism: Bringing you new Healthcare ideas so wonderful, they have to include mandatory participation ......
CJ7-Tim is offline   Reply With Quote Quick reply to this message
Unread 07-09-2015, 11:46 AM   #4
meangreeny
thanks tim that was my thoughts but wanted confirmation, looks like my friend just scored a gas tank skid
Unread 07-09-2015, 12:30 PM   #5
HS00XJ
I used a early gas skid and modded it to work on mine. They are hard to find here .
HS00XJ is offline   Reply With Quote Quick reply to this message
Unread 07-10-2015, 10:42 PM   #6
FairlanePhil
Same. It didn't take much to fit it
I have a ZJ skid on my latest XJ
Current: 99XJ 6.5 lift-Bought 2015
Sold: Patriot Blue 00 XJ.
'sploded: 01 stock-0331 head victim
FairlanePhil is offline   Reply With Quote Quick reply to this message
Unread 07-11-2015, 05:32 AM   #7
CJ7-Tim
CJ7-Tim's Avatar
ZJ gas tank skids will easily fit a 97-01, one bolt hole on each side needs to opened up slightly. IDK if they fit 1996 and older.
