Gas mileage drop from the late 90's to now - JeepForum.com
post #1 of 10 Old 03-21-2012, 08:10 AM Thread Starter
greenlawnjeeper
I ran across some old mpg paperwork that I had. In the late 90's when my 1996 Cherokee had 7K miles on it, I was getting 16-17 mpg non-trip mpg on it. Now (and it has been like this for at least the last couple-few years) it's around 12-13 mpg. Vehicle now has 90K miles on it and I'm running synthetic 10w-30 - back then I was running 50/50 GTX/Syntex 10w-30. Is this due to ethonol entirely or just the motor getting loose? thanks, Fred
'96 Cherokee Country, Magnaflow cat and Borla exhaust, Hella 550's, Up Country suspension, Michelin MS 2's in 235x15 and Edelbrock IAS shocks. 91K orig. miles - the wife uses it ('cept when I borrow it to go huntin').
greenlawnjeeper is offline
post #2 of 10 Old 03-21-2012, 08:32 AM
Azzy
Ethanol packs less energy per volume than gas. So, we are getting watered down gas at high prices, and higher food prices.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #3 of 10 Old 03-21-2012, 08:45 AM Thread Starter
greenlawnjeeper
Yea, I figured it would kill mileage but I didn't think by that much
post #4 of 10 Old 03-21-2012, 10:43 AM
Azzy
When I can find real gas for my bike, I get much better mileage and my power band moves a bit. Wish I could get the stuff they get in Alaska, no additives, just plain jane good old gas that stores for years without varnishing.
Azzy is offline
post #5 of 10 Old 03-21-2012, 07:24 PM
Reptile
1991 XJ Cherokee
I don't think ethanol alone would explain the change in mpg... What matters is the octane level. Gas formulation changes even between summer/winter seasons anyways. The change in oil wouldn't either.
You probably need a tune up. Start with the basics (air filter, fluids...). Make sure your battery conections are clean and corrosion free. Same with your ground connections. A bad sensor like the O2 sensor can have a major impact on fuel consumption also.
Reptile is offline
post #6 of 10 Old 03-21-2012, 09:26 PM
Reptile
1991 XJ Cherokee
And I would add to that change plugs wire and look for corrosion under the distributor cap. Made a huge improvement for me.
Reptile is offline
post #7 of 10 Old 03-22-2012, 09:13 AM
rsurran
Around here we have several gas stations that sell non-ethanol gas. It's a little more but the boaters, bikers, and farmers use it. Outboard motors, chain saws etc. really have problems with ethanol.
2005 WK, 5.7L, Gold, Leather
2003 TJ 4.0L Freedom Edition, Flame Red, 5 spd., CAI, Warn, stinger, Hella/KC trail lights.
Dick Surran
"When you stop contributing you are just taking up space."
rsurran is offline
post #8 of 10 Old 03-23-2012, 12:48 AM
Reptile
1991 XJ Cherokee
I think this would be more a chemical compatibility issue than a loss of fuel potency. I heard something about ethanol eating up fuel pumps on some older vehicles. Gas typically contains up to 10% ethanol.
Reptile is offline
post #9 of 10 Old 03-23-2012, 07:29 AM
Millermagic
Ethanol gas, old oxygen sensors, etc are contributing to it ...
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #10 of 10 Old 03-23-2012, 08:48 AM
Motorcharge
Plus, wires, filters (air, fuel, oil), pcv valve, distro cap, and distro rotor. Also seafoam it (NOT in the oil) or run fuel injector cleaner through the gas tank.
O2 sensor could be going bad or the injectors may just be old and need replacing.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
How rare are late 80's early 90's Cherokee in original good shape ? bigislandhikers XJ/MJ Cherokee Non-Technical Forum 18 07-05-2011 05:20 AM
How many high-mileage XJs with lifts installed late in their life? charger_340 XJ/MJ Cherokee Non-Technical Forum 33 12-18-2008 01:08 PM
Sudden gas mileage drop woodie416 XJ Cherokee Technical Forum 15 10-21-2008 06:25 PM
gas mileage drop with BB? MXdude105 XJ Cherokee Technical Forum 10 06-03-2008 09:40 PM
Late 80's aw4 into late 90's jeep Tj4rocks XJ Cherokee Technical Forum 1 10-11-2006 06:40 PM
