Front recovery point - JeepForum.com
post #1 of 7 Old 12-01-2010, 02:52 PM Thread Starter
300bhp/ton
1995 XJ Cherokee
Is there one?
I see there is something, but is it a lashing point or is it a proper recovery point? Am I ok to attach a rope to it?
What other options are there? Can I fit something like this to the front of my Jeep:
If so, how and where?
Thanks guys.
Ex Jeep owner. Currently lots of Land Rovers....
300bhp/ton is offline
post #2 of 7 Old 12-01-2010, 03:22 PM
JimmyDiablo
1987 XJ Cherokee
Rockauto.com Front hitch. I will be getting one soon.
"Gay, Stupid and Dumb" are not words that apply to inanimate objects, period.
When you deal with adults, expect to be corrected.
JimmyDiablo is offline
post #3 of 7 Old 12-01-2010, 03:44 PM
Durt_Diver
thats a legit recovery point..... if you have a frame. xj's are unibody so recovery gets a little tricker. you bolt that on to the xjs uniframe it will tear right out. one of the best value front recovery options is this IRON ROCK OFF ROAD: XJ Tow Hook Mount
-Jacob-
lockers don't work unless you have Rubicon stickers
Durt_Diver is offline
post #4 of 7 Old 12-01-2010, 06:42 PM
OldYellowXJ
1989 XJ Cherokee
That hook CAN be utilized safely IF he has no sway bar, one bolt through the rear most hole in the hook and sway bar mount, and weld all around.
The sway bar mount is plated on the inside of the rail. I've seen it with my own eyes. I have also used that exact style hook to help a friend recover her full size ford from a ditch on the side of the road 7 feet below the road surface.
OldYellowXJ is offline
post #5 of 7 Old 12-01-2010, 06:53 PM
Durt_Diver
oh ok. never heard of anyone doing that. sounds solid to me
-Jacob-
post #6 of 7 Old 12-01-2010, 07:00 PM
OldYellowXJ
1989 XJ Cherokee
I'll slap a couple pics up tomorrow when I have daylight to snap them.
post #7 of 7 Old 12-01-2010, 07:09 PM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
They make brakets you can attach the hook to so you don't have to weld anything. Makes it much stronger to pull from.
- Chopped / Locked
- Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Rule #1 - No talking about the weather!
BeachinXJ is offline
front , hook , proper attachment , recovery , tow , tow hooks , xj
need a cheap point of recovery NotDirtyEnough XJ/MJ Cherokee Non-Technical Forum 13 11-12-2009 06:20 PM
So, what do you use as a recovery point if they don't have hooks or something? willcherokeexj XJ Cherokee Technical Forum 29 06-25-2009 07:16 PM
Front recovery point product questions scavengerj XJ Cherokee Technical Forum 3 02-24-2009 09:50 AM
Is this hitch an ok recovery point? jmspradl XJ Cherokee Technical Forum 18 11-10-2008 03:05 PM
front recovery point Irongrave XJ Cherokee Technical Forum 17 03-03-2008 02:00 PM
