Fix my 91cherokee RUST Problem? - JeepForum.com
post #1 of 5 Old 08-19-2011, 10:33 PM Thread Starter
tv91cherokee
1991 XJ Cherokee
I have just purchased my first Jeep and am new to this forum. I went out and bought a 1991 jeep cherokee laredo with the 4L I6 automatic with 4x4. I only plan to use the jeep to get me through the fargo winter without being stranded. What precautions would you guys take with a jeep that is a 1991 before driving it everyday through a winter. Looks like it needs coolant, oil change, and the rear main seal looks like it could be a bit of a leaker. Surprisingly it doesn't look too bad for what I paid and given the odometer reading of 226,700 miles. Any pointers on what to look for that could be a potential problem come winter would be great. Thanks
tv91cherokee is offline
post #2 of 5 Old 08-19-2011, 10:47 PM Thread Starter
tv91cherokee
1991 XJ Cherokee
Rust Problem Almost Forgot
The driver side door has an astounding amount of rust. Is there anyway in particular I should go about fixing it. I am on a tight budget.
post #3 of 5 Old 08-20-2011, 02:06 AM
Adam
1987 XJ Cherokee
Do you live near a pick n pull? You can buy replacment doors for 50 dollars. Most older jeeps leak, if its hemorrhaging oil then get the leaks squared away. If it's just a few drops here or there i wouldnt sweat it too much. Stay on top of oil/filter changes and that str8 six will last. We are very visual people here on jeep forum, we like lots of pictures. Sounds like a great cherokee.
I have a jeep and it takes me places
Adam is offline
post #4 of 5 Old 08-20-2011, 11:30 AM
rsurran
I'm surprised you are not talking about a lift with the amount of snow you must get. You can put some larger tires on your jeep without lifting it. You can research the forums for sizes. I would put the biggest tires on it I could. I'd definitly look into remote start! Good luck with it. Will it snow anytime soon?
2005 WK, 5.7L, Gold, Leather
2003 TJ 4.0L Freedom Edition, Flame Red, 5 spd., CAI, Warn, stinger, Hella/KC trail lights.
Dick Surran
"When you stop contributing you are just taking up space."
rsurran is offline
post #5 of 5 Old 08-20-2011, 08:35 PM
DerMeister
Often, you can sand blast, bondo, prime, paint, clear coat. However if the rust is a really bad, you can cut it out and weld a patch in and follow the above list. However, I would just find a new door if the rust is seriously bad. It depends on where its at and how serious.
DerMeister is offline
Rust - POR15 vs. Rust Bullet vs. Eastwood Rust Encapsulator Jeep Cherokee XJ/MJ Cherokee Non-Technical Forum 15 02-10-2012 02:50 PM
2700$, right for a 91cherokee laredo??? G_baller XJ/MJ Cherokee Non-Technical Forum 18 09-14-2009 07:38 PM
Rust Problem barbmwi XJ Cherokee Technical Forum 3 06-11-2007 12:13 PM
Is Rust A Problem On Cherokees? FutureZJOwner XJ Cherokee Technical Forum 43 12-12-2005 08:55 AM
Gutter rust a common problem? 91GTA350 XJ Cherokee Technical Forum 9 04-03-2005 06:57 PM
