first time jeep owner - JeepForum.com
post #1 of 6 Old 06-05-2013, 11:09 PM Thread Starter
pipkns
1995 XJ Cherokee
I am in the process of getting my first jeep. I have found a 1995 jeep Cherokee sport for $500. it needs a motor and tires. I want to use this as my daily driver so I am just going to replace the 4.0 motor with a rebuilt one. I would like to know the best size tire to use for daily use and occasional off roading. everything is stock on the jeep. any information would be greatly appreciated
pipkns is offline
post #2 of 6 Old 06-06-2013, 02:05 AM
Muddy97Cherokee
1997 XJ Cherokee
What is wrong with the motor? If your replace everything on the motor, like harnesses and everything, make sure it's the HO 4.0 instead of the renix. Also stay away from the 00-01 for engines. Head cracking issues is to likely and they have coil packs, distributor is better. If is just the block any will work. Also don't try and swap a WJ or TJ motor in. It's a completely different block that requires some major mods to get it to all work.
For tires at stock height I would go with 235/75/15. Its the biggest tire size that you can fit at stock with no major issues. They are a tad bit bigger than the stock tire from the factory but work great on the XJ.
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
Muddy97Cherokee is offline
post #3 of 6 Old 06-06-2013, 06:11 PM Thread Starter
pipkns
1995 XJ Cherokee
The motor is knocking pretty bad. im not real sure what it is. not sure if im goimg to replace everything or just the engine. what is the difference in the HO and renix? thank you for all the information it has been very usefull.
pipkns is offline
post #4 of 6 Old 06-06-2013, 10:06 PM
dmill89
1995 XJ Cherokee
RENIX (Renault/Bendix) is the fuel injection / engine management system used in XJ Cherokees prior to 1991 (87-90). A 95 would not be Renix to begin with and as long as you stick to 91-95 parts you should be fine (96 went to OBDII). Before you do anything with the engine, check the flex-plate, a loose or cracked flex-plate on a 4.0L I6 will sound almost exactly like a bad rod knock.
HO stands for High-Output but is basically meaningless since every 91 and newer 4.0L I6 is an HO. So they are only "High-Output" in comparison to older Renix engines and it isn't that big of a difference anyway.
dmill89 is offline
post #5 of 6 Old 06-07-2013, 07:47 AM Thread Starter
pipkns
1995 XJ Cherokee
thank you muddy97cherokee and dmill89 for the information you have given me. it has all been very usefull. im sure that I will have many more questions as I dive into the world of jeeps
pipkns is offline
post #6 of 6 Old 06-07-2013, 09:59 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
It stands for Highly Overrated actually.
Here's a nifty write-up with photos on checking those flexplate bolts.
http://www.cherokeeforum.com/f51/how...ocking-125547/
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
