Fender Trim - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Fender Trim
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 02-04-2016, 01:17 PM   #1
danlikescoldbeer
Fender Trim
What did you guys use to trim the fender after cutting?? I was going to use Protekto http://shop.cowlesproducts.com/c/pro..._5-8-lip-style
Not sure if 20' will be enough. Do you know how much you used?
2015 Grand Cherokee Altitude
1999 XJ
danlikescoldbeer is offline   Reply With Quote Quick reply to this message
Unread 02-04-2016, 03:32 PM   #2
Metro55
Metro55's Avatar
nothing at first, then I used 1 5/8 tube lol
.,,_____,====,
//__l_l_,\____\,_____
l_,--\_l__l_/--|[]llllll[]|
,(•)_),,,,,,(•)_)--o-)_) Caged
Metro55 is offline   Reply With Quote Quick reply to this message
Unread 02-05-2016, 09:40 AM   #3
danlikescoldbeer
My concern is the length needed. Do you know how much you used? I guess I could just measure my fenders with rope and measure the overall length.
1999 XJ
Unread 02-05-2016, 04:53 PM   #4
Slvr01Sport
Dan, look at his build then you'll see what tubing he used...
Slvr01Sport is offline   Reply With Quote Quick reply to this message
Unread 02-09-2016, 03:29 PM   #5
bluejunior
That's the best way. Use some twine or string, then add a 6" safety margin per fender.
Lifted, Locked, Stiffened
Build
bluejunior is offline   Reply With Quote Quick reply to this message
